D2 5U fan belt adjustment
Potato Wilson
Thank you received: 26
Howdy Folks,
I need to replace or at least adjust my fan belt. The adjusting sheave was frozen up, but I got it to move some by soaking it with Kroil for a few days, and rapping it with a wood block and hammer. IS THERE A SPECIAL WRENCH FOR TURNING THIS?
I’m also going to need to rebuild the water pump sooner or later. Is there someplace to buy a rebuilt one, or is it strictly a bench job?
Thanks!
PW
Mon, Nov 10, 2025 6:01 PM
Thank you received: 78
Once mine was freed up, I used a c-spanner. You could easily make one out of a piece of 3/16 mild plate, cut to the perfect size. I don't know about rebuilt pumps but you could check with Cat parts to start with. I think it's not too bad of a job to do yourself apart from having to be careful with the seal
Mon, Nov 10, 2025 10:17 PM
