D2 5U D311 Engine & Chassis Design Change Interchange
Showing 1 to 6 of 6 results
PeterS
Send a private message to PeterS
I have two D2 5U's. The early one, 5U1949 is a crawler with a PTO. Bottom is very good, but no blade and tired engine. The second is a 5U15739 that seems to have a very powerful engine but rough chassis. Although I would like to keep my early crawler original, we need a machine to do dozer work with. If I understand correctly my crawler is pre design change and my later dozer is after design changes. How would these changes effect the interchangeability of the D311 engine and dozer parts in my situation? Sorry if this has already been covered, I tried to search first.
Thanks very much,
Peter.
Mon, Jan 23, 2012 3:14 AM
PeterS
Can anyone direct me to an archive on this subject. I searched the best I could and had no luck.
Thanks, Peter.
Mon, Jan 30, 2012 10:34 PM
bcwayne
Reply to PeterS:
Thanks, Peter.
One of the biggest differences in your tractors is the later one is approximately 6'' longer to allow for changing the flywheel clutch without removing the engine. The extra length shows in the longer track frames, sloped top bell housing, and hood.
As far as the actual D311 engine goes, I believe the engine from your later tractor will bolt right up to the earlier bell housing with no issues or modifications.
If I'm mistaken, someone please jump in and say so... Thanks, Wayne
Tue, Jan 31, 2012 3:45 AM
Reply to bcwayne:
what i found in my parts books is that the engine block assembly had different part numbers--4F4165 for the earlier machine and 3H9070 for the later machine.
Tue, Jan 31, 2012 7:09 AM
josh
Thank you received: 13
Reply to dpendzic:
The later engine should bolt right up, the 4F4165, and 3H9070 blocks show as being the same. Mounting a cat dozer from a later D2 to an older one will cause some issues, the mounting brackets from the later one will move the blade an extra six inches further out in front, making an all ready hard to control dozer much worse, and if you were to try to put a dozer from an older model to the later one, it would not fit. The blade itself, and the C frame, if it is an angle dozer are the same size wise, old to new, it is just the mounting brackets that are different, the steel hydraulic lines that go across the dash may also be different enough to not fit.
Tue, Jan 31, 2012 10:00 AM
flmore
Send a private message to flmore
Reply to dpendzic:
No problen. The later engine will bolt right up.
PeterS
Reply to flmore:
Thanks guys....that is good stuff and exactly what I was looking for.
Thanks again, Peter.
Wed, Feb 1, 2012 10:59 PM
| Kingaroy, Queensland
