D2 5u clutch question?
Showing 1 to 10 of 41 results
Jw74
Send a private message to Jw74
Hello every one I hope all is well. I have removed the clutch assembly from by D2 and am wondering how to get it apart to replace the disc. I have read from some previous threads that this disc should be replaced if worn down below .600 well mine measures around .530 and also am wondering if the disc is supposed to stay centered in the assembly because this one does not. you can slide it back and forth in between the pressure plates as if the center of it is worn out. the part number my book shows is 5f7434 can anyone verify if I need to replace this disc thanks!!
Thanks God Bless
Sun, Oct 19, 2014 8:37 AM
Jw74
any information would be greatly appreciated thanks!
Thanks God Bless
Mon, Oct 20, 2014 10:14 AM
Reply to Jw74:
I'm 12 hours out, got one laying on the shop floor but can't remember right now??
On the Road.
It unscrews but I can't visualize it in my mind to explain it now....
Mon, Oct 20, 2014 7:57 PM
bcwayne
Reply to drujinin:
On the Road.
The pieces separate by unscrewing the spider assembly containing the brass collar and links from the front pressure plate.
There is a spring loaded knob on one of the spider legs... pull it back about 1/4'' and unwind the spider... lift off the spider and the 2 pressure plates and disc are now apart.
It's normal for the disc to have side to side movement between the pressure plates... upon reassembly you will center it between the plates by eye, and tighten the spider just enough to hold it there while indexing the engine flywheel.
Mon, Oct 20, 2014 9:42 PM
Reply to bcwayne:
I got home a couple of hours ago, just sitting down to relax and remembered this!
He is right that when you unscrew the "spider" that the plates will come apart!
Thanks!
Tue, Oct 21, 2014 6:10 AM
Jw74
Reply to drujinin:
Thanks!
great thanks guys I think I will go ahead and replace the disc wile I have it all apart. My local cat dealer wants 600.$ for a new disc does any one have a good source on this the number from my book is 5F7473 I will give florin tractor a call tomorrow and see what they have available
Thanks God Bless
Tue, Oct 21, 2014 8:51 AM
bcwayne
Reply to Jw74:
The disc is availible from General Gear for around $150.00
Tue, Oct 21, 2014 9:08 AM
Jw74
Reply to bcwayne:
thanks BC I ordered one the next day after you let me know about it and had it two days later and the price was 149.00
Thanks God Bless
Sun, Oct 26, 2014 8:55 AM
Jw74
Reply to Jw74:
hi guys I am having trouble finding the inner race (4B3712) and seal (1B1069) for the shaft and bearing that goes inside the flywheel I was able to find the bearing and outer race but my local cat dealer told me those two parts were discontinued does any one have a good source for these two parts ?
Thanks God Bless
Tue, Oct 28, 2014 10:57 AM
Reply to Jw74:
Florin tractor shows having both....
Tue, Oct 28, 2014 12:51 PM
Once you get them from Florin, could you post the manufacturers part numbers assuming they won't have just CAT part numbers on them?
A month or three from now someone else will be looking and it would be nice to have an aftermarket part number available to them.
Thanks!
Tue, Oct 28, 2014 5:42 PM
