D2 5U Clutch Parts
D2 5U Clutch Parts
rlitt
Send a private message to rlitt
Found these while draining the oil from the clutch compartment. They look like gear teeth. They are not metal but a fiberous material. What are they?[attachment=49271]C98649BF-0D59-4D84-8795-97B126BE2B81.jpg[/attachment]
Sun, Jun 10, 2018 7:54 AM
d2gary
The clutch plate has gear teeth cut in it. Looks like teeth from it. Mine let go after about 1/3 of the teeth were broke. You might think about a little clutch inspection. If your 5u is late enough it has the clutch with the collar so not to bad to change
Sun, Jun 10, 2018 8:00 AM
rlitt
Reply to d2gary:
Thanks Gary
Sun, Jun 10, 2018 9:53 AM
Thank you received: 77
Reply to rlitt:
Thanks Gary
You can get new clutch plates from General Gear (tractorparts.com)
Sun, Jun 10, 2018 6:29 PM
