D2 5U brake band relining
pgill
Send a private message to pgill
I am a new member and have recently purchased a D2 5U project. I have been using information found here to help me with this restoration project, very helpful.
I am interested in trying to reline my D2 brake bands myself. I see that McMaster Carr sells several types of brake lining sheets. Has anyone done this? any input would be appreciated.
P. Gill
Mon, Oct 3, 2016 8:56 PM
Thank you received: 27
Hopefully the lining and rivets are still available from Cat. It has been several years since I have ordered any but the last I purchased for the same vintage D6 came drilled just rivet it down. I have also purchased from some after market suppliers that are listed at the top of discussion page.
Mon, Oct 3, 2016 10:03 PM
Thank you received: 19
Reply to Ray54:
I'd recommend you stay away from the aftermarket brake linings. I've had feedback that some of them are pretty bad with very little service life. It's also not worth messing with home made versions. Take the bands to any good commercial clutch/brake relining shop and have them redone there. Good rebuilds use a combination of rivets and bonding with modern adhesives.
Mon, Oct 3, 2016 10:30 PM
pgill
Thanks for the help. I'll check around to see if I can get this done locally. I tend to be frugal and design and build where I can. Looks like new brakes are ~$130 each. If I do decide to do this on my own I'll let you know how it goes. Thanks all...
Mon, Oct 3, 2016 11:07 PM
Reply to pgill:
I might have a good set of brake bands? Let me know if you are interested and I'll look.
Jeff
Tue, Oct 4, 2016 7:42 AM
D6 Pete
Reply to drujinin:
Jeff
Good friend in North CA has done many bands !! and has for most Cats ..
Wed, Oct 5, 2016 5:28 AM
Gregness
Reply to D6 Pete:
I don't imagine there's any way to get the bands off without tearing the whole back end apart...
Wed, Oct 5, 2016 9:18 AM
pgill
Reply to Gregness:
Jeff. I would be interested in a pair after brake bands. I pm'do you for more information. Thanks. P. Gill
Sun, Oct 16, 2016 10:04 PM
Oldrnu
Send a private message to Oldrnu
Reply to Gregness:
That's right. Pull the seat/fuel tank, pull the tracks, then pull the finals. I just replaced a steering clutch throw-out bearing on mine and it took about 10 hours to pull it down for the first time. I would certainly try all the adjustment first before starting.
Sun, Oct 16, 2016 11:28 PM
