d2 5u blade pin rebush questions.
Showing 1 to 10 of 14 results
scott in wa.
Send a private message to scott in wa.
I 've got a question about a total re-pin and or bushings on this tool bar blade I have.
Its really sloppy, the blade will actually move enough to where it rubs on the tracks up front when un even pressure is put on the dozer blade.
I'm not sure this type blade is designed to do any serious pushing of hard packed dirt.
how do you guys re-bush these?
I see 2 ways to go.
Ream until round (100 percent clean up) cleaning up holes then make a oversize pin. all of them are sloppy.
or ream them a bit oversize, sleeve them, make an origin size pin.
maybe make the new pins out of 4340, then heat treat with torch, then oil quench?
I've got a lathe and a mill, so I could do it my self.
anyone ever done this?
I don't like the blade moving side to side. scary.
more issues to come but this one sticks out.
I do notice on the rear on the tool bar mount, it actual has stops (a long bar), I assume they are there to prevent the blade bars from hitting the rear part of the tracks, the front don't have this bar that's part of the mount system
what's the best way to go.
thanks much scott
1938 d2 3j
1954 d2 5u
1959 440 icd
model 51 rotary valve hoe
1956 IHC S170 dump
Fri, May 29, 2015 11:05 PM
I would say there is almost always plenty of "meat" around the bores to ream to an oversize and get new pins.
Lots of similar problems fixed by welding them in and boring back to standard. Especially useful for things like articulation pivots where making oversize parts is more of a chore than some straight pins.
Sat, May 30, 2015 12:46 AM
Seems I'm always dealing with the task of hogged out holes. Some brackets I torch off and make new, some I torch out the holes and replace with DOM tubing, some I align bore in place and install bushings.
I'm a big fan of "Connex" spring bushings.
http://www.connexusa.com/HTML/Spring%20Bushings.html
Sat, May 30, 2015 1:11 AM
scott in wa.
wow, ya those bushings look interesting.
when you re-did the holes and bushing or/ pins did the blade movement from side to side minimize?
mine will actually rub if give the right circumstances.
its a tool bar blade set/up
thx
scott
1938 d2 3j
1954 d2 5u
1959 440 icd
1956 IHC S170 dump
Sat, May 30, 2015 3:14 AM
Reply to scott in wa.:
thx
scott
It's mainly the function of the diagonal blade braces to keep the push arms parallel. I'd go after them first.
Sat, May 30, 2015 3:22 AM
Chuck C
OM has a point the diagonal braces stop the side to side movement. when the blade is removed the diagonal braces stay on the blade and the arms turned to the rear the slides on the side of the track frame check the side to side movement when the tool bar is on the rear.
Chuck C
Sat, May 30, 2015 8:12 AM
Steve A
Reply to Chuck C:
Chuck C
My 5UD2 has a tool bar and every joint was loose, I welded, bored and made new pins, a lot of work, I like the bushings OM posted,I can why he likes them.
Sat, May 30, 2015 9:03 AM
Inter674
Reply to Steve A:
Good suggestion Om.
I've Used spring bushing myself for new pins where there's enough meat to re-bore and they work real guuuud and are replaceable down the track. Certainly saves a lot of hard yakka in welding and re-boring back to nominal size and I like the fact that they are reasonably forgiving in terms of fit.
I also used one in a slogged out idler gear bearing in a winch by boring out 90% of the damaged section to create a reasonably paralell hole and inserting a bronze spring bushing to match the new hole and existing shaft size. Cost about thirty dollars and worked like a treat. The quote to get a new gear cut was 1500 dollars😊
Sat, May 30, 2015 12:00 PM
mrsmackpaul
Reply to Inter674:
Good suggestion Om.
is there some reason you cant use tractor 3PL top links for the diagonal braces that way you can adjust the slop out and the problem would be solved or at least buy you a whole heap of time till you get the time or cashed up enough to fix it properly and they come with different size pins 3/4 - 1 1/2
http://www.ebay.com.au/itm/TLK3011-Tractor-3PL-Top-Link-with-12in-30cm-Tube-Cat-1-3-4in-at-both-ends-/271351015098
Paul
Sat, May 30, 2015 1:37 PM
scott in wa.
Reply to mrsmackpaul:
Paul
Boy, there is an amazing amount of experience & knowledge here.
I didn't think of that either, could work.
I will look into it. they would have to be big tho.
This Dozer have plenty of issue, seems like all of mine do.
I don't want to inundate the experts here with them all at once.
I took a tumble on Sunday that set me back, as far as working on this thing. i'm back to doing nothing again
so all I'm doing right now is sitting in my recliner, looking at manuals and thinking about how to go about addressing them. (boredom)
The blade is better with the new cylinders, but still not 100 percent, maybe 50 percent better than it was.
really really helpful when you cat skinners reply, I appreciate the help and suggestions. excellent stuff
I thank you all fro the help.
scott
1938 d2 3j
1954 d2 5u
1959 440 icd
1956 IHC S170 dump
Sat, May 30, 2015 10:08 PM
mrsmackpaul
scott
hey you be careful and take care of your self hope you are feeling better soon
Paul
Sun, May 31, 2015 2:54 AM
