D2 5U Battery
D2 5U Battery
Steve1ac
Send a private message to Steve1ac
Hello to all.
Dad passed a couple of years ago and  the d2 has to move on to the next owner. 6volt pony start.
Well removed the battery last fall and I can’t remember if this positive or negative ground.
This machine is all original to the best of my knowledge.
Mon, Jan 2, 2023 10:49 PM
Thank you received: 270
I have always been told the starter does not know the difference; majority were set up as positive ground. It would be important if your charging system (if any) was intact and functional. Many of us will just use a 12V battery, as 6V are becoming scarce; just don't crank on it for long periods of time! JM
Mon, Jan 2, 2023 10:56 PM
Steve1ac
Yes That’s correct on the starters I do have some old antique farm tractors and converted them to 12 V. All of the wiring for the pony appears to be all original and intact.
Mon, Jan 2, 2023 11:19 PM
side-seat
Thank you received: 15
Reply to Steve1ac:
Negative Ground system.
Where are you located?
Mon, Jan 2, 2023 11:30 PM
Mschwartz
Reply to side-seat:
I would take a look at the battery cable ends, the positive terminal is the larger one. Not always 100% correct but you would at worst be connecting it up the way it was used last. Good luck, Mike
Mon, Jan 2, 2023 11:46 PM
steeltracs
Thank you received: 10
Reply to Mschwartz:
In general 6volt systems are positive ground on most other (non Cat) makes and 12 volt are all negative ground. On 6 volt the difference is the charging system regulator if it is positive or negative ground
Tue, Jan 3, 2023 1:20 AM
Reply to steeltracs:
Cat 6V systems are NEGITIVE GROUND!!!!!!!!!!!!!
Tue, Jan 3, 2023 5:05 AM
Thank you received: 52
most automotive electrical systems are negative ground it was the Europeans particularly British and some Japanese manufacturers the used positive ground. have a look at the charge regulator that will tell you provided the tag isnt gone.
six volt batteries are still available you may have to order them in though.
Tue, Jan 3, 2023 5:55 AM
Steve1ac
Reply to side-seat:
Thanks for the input located in Ohio between Columbus and Cleveland
Sun, Feb 5, 2023 9:26 PM
