d2 5u 6 volt battery box dimensions needed
Showing 1 to 10 of 10 results
m249bb
Send a private message to m249bb
I am in need of the dimensions of a 6 volt battery box for a 5u d2 cat with electric start. I have searched the discussion form with no luck in obtaining the correct dimensions for fabrication. Any info is appreciated as Im going to have one fabbed at a shop as a replacement.
chuck
Sun, Oct 20, 2013 10:47 PM
Jim Davis
Send a private message to Jim Davis
I have a rusted out battery box I took off a 5U. I will measure it tomorrow for you if I remember. Couldn't tell you if it was for 6 volt battery, but I'd guess it was. you might consider going to 12 volts, since batteries are much easier to come by...
Jim
Mon, Oct 21, 2013 7:32 AM
m249bb
Reply to Jim Davis:
Jim
Thank you Jim. Any info is greatly appreciated.
charlie
Mon, Oct 21, 2013 8:42 AM
Reply to m249bb:
charlie
I am thinking that Sasquatch rebuilt one with photo's two or three years ago?
I saw the photo's which means it was posted somewhere?
Mon, Oct 21, 2013 6:15 PM
Jim Davis
Reply to drujinin:
The top cover to mine is missing. Apparently, it was fastened on by two 1/4" cap screws or thumb screws that fit in two nuts welded into to opposite corners of the box.
Here are the dimensions of the box;
Length inside--12-1/2"
Width inside--8-5/8"
Height--9-1/4"
Stands on round steel feet 1-1/8" long, 1-1/4" in diameter that have a 1/2-20 integral stud on the bottom about 3/4" long.
There is a separate platform in the bottom of this one that measures 10-1/4" long by 6-1/4" wide. The platform has a metal L-shaped leg that extends under and upward with a threaded section on the top. This seems to have been part of way of clamping the battery in place.[attachment=20122]battery box face.JPG[/attachment][attachment=20123]battery box floor plate upside down.JPG[/attachment][attachment=20124]battery box from above 2.JPG[/attachment][attachment=20125]battery box from above1.JPG[/attachment]
Mon, Oct 21, 2013 9:03 PM
m249bb
Reply to Jim Davis:
Height--9-1/4"
Wow,
Excellent description and write up Jim.
That is exactly what I needed.
Thank you!!
charlie👋
Mon, Oct 21, 2013 9:44 PM
Reply to m249bb:
Wow,
Thank you!!
charlie👋
mine is 7 3/8 wide and 11 3/4 long--someone along the way added to the height
.[attachment=20174]D2 4U 004.jpg[/attachment]
Wed, Oct 23, 2013 3:42 AM
ianoz
Reply to dpendzic:
Just a word of warning .We just bought a D4 ,with electric start pony .Previous owner had replaced the battery and found the modern battery would not fit in the box ,so cut the end out to fit it in .Battery is higher as well so lid won't go on .
Having the correct size box is all well and good ,but useless if the battery won't fit inside it .
Wed, Oct 23, 2013 6:15 AM
m249bb
Reply to ianoz:
Thanks for the heads up on that.
I wondered if it might be a issue.
charlie
Wed, Oct 23, 2013 10:12 AM
AaronH
Send a private message to AaronH
Reply to m249bb:
charlie
I can tell you that a 12 volt group 85 battery will fit in place of the old 6 and 8 volt group 1 batteries.
Operating a sanctuary for all things rusty or broken. Current residents include: Allis Chalmers WD45, Oliver Row 77, two Cat D2's, Clark C500-80 forklift, and a wounded Kubota.
Thu, Oct 24, 2013 5:35 AM
AaronH
Reply to AaronH:
Here are two pictures of the group 85 battery.
[attachment=20212]IMG_20131023_182622_512.jpg[/attachment][attachment=20213]IMG_20131023_182630_060.jpg[/attachment]
Thu, Oct 24, 2013 9:06 PM
