d2 5u 4 roller to 5 roller
zep
Send a private message to zep
I have a nice d2 5u crawler that i'm considering swaping to a 5 roller with solid front idllers and a blade aet up.I have found a newer than mine 5u with blade and 44 pump.Is this a straight forward swap?I should have almost a complete d2 left over.Thanks,Tim
Mon, Apr 1, 2013 6:40 AM
If the donor tractor has the longer frames and rails, its a blood, sweat conversation!
Blood from busted knuckles and skinned shins, sweat from moving all that heavy iron!
Use the SEARCH function in the upper right of your screen to find more Threads on the subject, its been discussed before as the D2 is quite popular!
Mon, Apr 1, 2013 8:50 AM
d4e
Send a private message to d4e
Reply to drujinin:
If the blade you are installing is a 2A you will need 13 in pads with a 5 roller frame. The 13 inch pads I had on my late 5U with a 2A blade had very little clearance between the pads and c frame.
Mon, Apr 1, 2013 10:05 AM
