D2 5J1404SP, year? "Pony Coolant Vent"?
CatsRgr8
Send a private message to CatsRgr8
I am trying to go through all 660 (GULP!) pages of the Forum looking for any posts on D2's. I am now on page 160 and have logged and cataloged well over 150 threads. On page 160, is a post about a D2 that the cooling system would not drain. The bottom of the radiator drain was discussed and the one at the rear of the block near the pony oil tube. But then there was discussion of a VENT on the top of the pony engine. I can't find anything that looks like a VENT that can be opened on my 5J 1404SP pony engine. Was that only on newer tractors?
And mine is a 1939, correct?
Sun, Oct 23, 2016 11:31 AM
STEPHEN
If you have one it is on the manifold top, right side. It is a small brass cock just like the compression relief/cylinder drain valve. Look close, it can be hard to see and operate.
Sun, Oct 23, 2016 12:12 PM
Sasquatch
Reply to STEPHEN:
Check out this old thread, several pages long but worth reading to study up on the pony motor top cover vents, pics of the early covers that originally didn't have them and also the later ones that did, plus the pros/cons of drilling and tapping the early covers to accommodate a vent petcock.
http://www.acmoc.org/bb/showthread.php?19988-D2-Pony-Motor-over-heating
By the way, 5J1404SP is a 1939 model.
Sun, Oct 23, 2016 12:19 PM
CatsRgr8
Reply to Sasquatch:
My engine is too early to have any kind of vent. I noted the instructions for adding one (invaluable! Thanks) but I don't seem to have any heating problems. Is it worth taking a chance on trying to tap a thin casting just to have one? I have a 1200 Watt pump type heater on mine, so I thoroughly warm it up with that before I try to start it. Maybe that pumps the air out somehow. I think my cooling system is pretty clean. My pony runs perfect, starts instantly, does not leak oil, but does have crankshaft end play, so I try to spare it as much as possible.
Sun, Oct 23, 2016 2:23 PM
Reply to CatsRgr8:
If the Pony isn't overheating, then I would not worry about trying to install the Vent. It only seems to be there to assist in filling the Pony.
Sun, Oct 23, 2016 6:48 PM
Thank you received: 24
Reply to drujinin:
Another way to assist with venting is to drive the tractor up a slope momentarily
Sun, Oct 23, 2016 11:54 PM
Earlcoate Charity Open Day
