d2 5j wrench size
d2 5j wrench size
powergiant
Send a private message to powergiant
I'm looking for the size wrench the adjusting nut on the idler spring takes.
Looks close to 2 1/4" - just looking for verification - I'm not fond of the pipe wrench approach- thanks
Fri, Jun 25, 2010 7:50 AM
B4D2
What are you afraid of? Nothing the Bravo Foxtrot Hotel can't handle... 😆 P.S. Yes your assumtion is correct; 2-1/4"
Fri, Jun 25, 2010 8:02 AM
side-seat
Reply to B4D2:
Look for a Proto 2-1/4" combination wrench on ebay or similar type.The Proto wrench is much more longer and the head is slim. 👍 The original Armstrong open end wrench's head is too big and is short as I found out one time when I threw a track in the woods just before I was to cross a small creek. It doesn't leave much room to turn maybe a 1/16th turn at a time and that's from turning it over on every turn. It took me about 2 hours to back the adjuster off to reinstall the track. Now this was on a D2 with a tool bar and I also had to remove one pin and swing the hyd. cyl. out of the way. :frusty:
Fri, Jun 25, 2010 8:58 AM
powergiant
Reply to side-seat:
I can relate. I was working on a sidehill and lost a track on the low inside. I was able high side track to dug down more level and jack up the low side. Used a chain and rear sprocket to pull the idler back along with a comealong. At any rate I got everything backed off, pulled the plugs and drove the pin out last night. Now just need to get it all back together.
Fri, Jun 25, 2010 11:11 AM
