D2 5j pony motor engagement
davidbrodhead
Send a private message to davidbrodhead
The pony motor is disengaging too soon on my D2 5j.If I give the diesel the least bit of fuel the the pony motor speeds up enough to kick it out of gear.Anybody know where the adjustment is on these things?
Fri, Oct 1, 2010 7:43 AM
look for a small cover held on the clutch housing by 2 bolts. It's near the left brake pedal and over the pony pinion. Take it off and you should be able to see the adjustment screws which are locked with cotter pins. Turn in half turn at a time, keep the two of them even. You can also have worn latches etc that make them release too early.
Fri, Oct 1, 2010 10:41 AM
Earlcoate Charity Open Day
