D2 5J oil filter change on YouTube
bvandragt
Send a private message to bvandragt
I just saw this on YouTube:
https://www.youtube.com/watch?v=tj6iCGolTRo
He has a paper oil filter inside a brass screen. Is that right? I thought you had one or the other depending on whether the housing had been updated for paper filters.
Brian
Sun, Jan 5, 2020 2:35 AM
That’s correct. The bypass filter arrangement uses the brass screen to filter the bulk flow to the bearings and the paper cartridge to filter the bypass flow. In its time it was an improvement over previous types. The paper filter technology could not pass the full flow without being huge but could filter part of it through a reasonable sized filter. It was a step in the right direction.
Bypass filters are sometimes used today for the additional reduction in very small particles that are typically not removed by full flow filters.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare timeđŸ˜„
Sun, Jan 5, 2020 4:08 AM
bvandragt
Okay. It seems like a good topic for a Squatch253 video, hint, hint. 5J1113 is about ready for an oil filter.
Brian
Sun, Jan 5, 2020 9:25 AM
| Kingaroy, Queensland
