D2 5J Fuel System Advice Needed
Showing 1 to 10 of 11 results
Lineshaft Restorations
Send a private message to Lineshaft Restorations
Calling all D2 5J D3400 experts. Well like many things I have learned about this 1941 D2 5J I have, there is always another
thing to deal with is right around the corner.
As a prelude to remounting my rebuilt pony motor I figured, that since the goveror housing was already off, I would
remove the injection pump to reseal the pump drive since the injection pump does not share engine oil and it is quite
likely the original 1941 seal is in place.
When the injection pump assembly was separated from the fuel filter housing a little fuel came out but almost no oil.
The fuel gallery from the fuel filter housing leading to the individual pumps had nearly 1/4" of sludge in it. This
was probably why the engine ran with a miss when it was first run. https://youtu.be/s9rpdPQ-4dc
The sump too had nearly 1/4" of sludge in it and no free flowing oil. The fill cap on the hour meter was painted
over like it had not been opened since the whole engine was last painted.
So now to the questions.
Can the injection pump sump and fuel galleries be safely washed clean without disassembly? I have read that
disassembly of the individual pumps is not recommended.
Can the fuel filter housing be effectively washed clean without removing it from the engine? It appears the filters had
not been replaced since the engine was last painted many many years ago too.
What is the part number of the fuel gallery seal between the 7B6643 filter housing and the 2A5700 pump body? It is
rubber and roughly conical in shape. My parts book does not identify this part. I suppose a properly sized O-ring
could be used if a proper replacement cannot be secured.
I have a replacement 2A3337 gasket for between the pump and fuel filter assembly, but the 4B5874 gasket between the
pump and governor assembly is elusive. CAT has it in their parts inventory system but no stock. Any ideas?
Thanks,
Patrick
Fri, Aug 9, 2019 12:20 AM
Thank you received: 61
Try Florin for your gaskets, or Olson. You should remove the plugs and pumps from the injection housing to clean it, and I'm not sure about the 3400 injection pumps but on my 311 pumps, I just pulled the plunger out of the pump and flushed everything with clean diesel. The gallery in the injection housing on mine was full of crud so I'm glad I cleaned that out or I could have ruined the pumps. That conical seal is actually just a regular o-ring if I recall correctly - could be wrong
Fri, Aug 9, 2019 1:03 AM
In the photos on the fuel tower is the funnel shaped cone with the plug?
That should be the bottom of the fuel tower. (If I remember correctly?) Remove the filters and take a look down there. I did one a long time ago that was full of crud and stuff. Using a long handle screwdriver and coat hanger to scrape and push the crud to the bottom while pouring lots of diesel through to flush. The O-Ring is correct, they become Conical with age.
Fri, Aug 9, 2019 6:32 PM
Reply to drujinin:
I attempted to drain the fuel filter tower in place but what came out was more like diaper leavings so I disassembled the whole thing for complete cleaning.
It looks like draining and flushing was never done. Perhaps last time was 50 or 60 years ago. Judge for yourself.
[attachment=55021]IMG_2009 - Copy.jpg[/attachment]
Fri, Aug 16, 2019 3:07 AM
Reply to Lineshaft Restorations:
Not uncommon that's for sure. My 5U looked just the same. A thorough cleaning and it's as good as new. Surprised it even ran before but then I guess the sediment was just in the right place to avoid being picked up. I added an inline filter before the transfer pump that will clean the fuel very well before it gets near any components
Fri, Aug 16, 2019 7:26 AM
Florin had some of the gaskets needed.
There is a seal for the clean fuel passage of the filter tower to the injection pump. My parts manual does not show it. My local Cat dealer cannot bring up the fuel filter assembly to even search.
Check out the images. Any idea of a part number?
[attachment=55154]CleanFuelSealToInjectionPump.jpg[/attachment][attachment=55155]IMG_2043.jpg[/attachment]
Fri, Aug 30, 2019 10:26 PM
d2gary
Thank you received: 50
Should be 2A3854
[attachment=55156]20190830_083559-3096x2322.jpg[/attachment]
Fri, Aug 30, 2019 10:40 PM
Reply to d2gary:
Should be 2A3854
Wish my parts manual had that detail. Thanks.
The one last item i need to deal with is the coolant diverter or whatever it is called that provides heat to the fuel filter tower.
Again my parts manual does not show this which makes me think it was an option. I need the gaskets part numbers.
[attachment=55216]20190903_132819 - Copy.jpg[/attachment]
I have been fortunate that Cat or Florin has had 90% or more of the gaskets and seals needed for this D2.
Easier to buy them than make especially if the gasket is used to establish clearances between parts.
Thanks again.
Wed, Sep 4, 2019 4:35 AM
Thank you received: 48
Thanks again.
It's all in the parts book, just have to know where to look.
Look under water lines.
Elbow is a 2A5767, gasket is a 2A5769
Wed, Sep 4, 2019 6:21 AM
I think I have a different configuration that what my parts book says I should.
I have a parts book that covers 5J3501-5j10561 which is correct for my tractor.
It say I should have a 6B4413 thermostat housing. Mine looks way different.
[attachment=55221]WatreLines.jpg[/attachment][attachment=55222]IMG_1147_Elbow.jpg[/attachment]
Could this configuration be pre-5J3501? My tractor SN says it is early 1941.
The main engine and pony blocks were cast in 1940.
Wed, Sep 4, 2019 10:44 PM
Looks the same although the photo is from the other side of the tractor from the part catalog drawing. Looks the same as the one on my 3J if I recall correctly
Thu, Sep 5, 2019 2:33 AM
