D2 5J adding external fuel filter
vansgarage
Send a private message to vansgarage
Need to know the thread/fitting type and size on the fuel line, (and dia.), inlet to transfer pump, 5J- fender tank. Adding a canister CAV delphi filter. Want to make up in advance tractor is up in woods on the job. Thanks for any replies Joe Van.
Tue, Jul 18, 2023 9:55 AM
Thank you received: 54
it is NPT. all the threads on these old girls are SAE threads. i thinks its 3/4
Tue, Jul 18, 2023 3:19 PM
PhilC
Reply to trainzkid88:
Don't know about the D2 but my D6's are all 1/2" lines.I think even the D8's are only 1/2 as well.
Tue, Jul 18, 2023 5:12 PM
Thank you received: 77
Reply to PhilC:
My 5U is 1/2" I'm pretty sure.
Tue, Jul 18, 2023 8:15 PM
bcwayne
The fuel line is 1/2'' ID. Original was steel. The fitting at the transfer pump is 7/8'' x 14 tpi straight pipe thread... not tapered pipe thread. You can use a -10 O ring boss fitting into the pump, and your choice of fuel line or hose from there.
Tue, Jul 18, 2023 9:04 PM
vansgarage
Reply to bcwayne:
Thanks guys, I thought I remembered it being a straight thread, could not remember if there was a seat or 0 ring, I was pretty sure on the 1/2" steel line. I don't like using rubber due to varmints chewing on it. Thanks again. Joe Van.
Tue, Jul 18, 2023 9:30 PM
