D2 4U466 Starting Engine Issue
Showing 1 to 10 of 12 results
r4dan
Send a private message to r4dan
The Starting Engine Pinion BRAKE is no longer stopping the pinion so it wants to grind even if I idle as low as possible .... it no longer stops the pinion.
To save the diesel ring gear, I now start / warm up the Starting Engine, shut it off, engage the pinion and then with pinion clutch released, start up the little engine again and engage the clutch ... clutch brake definitely needs attention!
Is the pinion brake adjustable?
I just ordered an engine Service Manual but not yet received .... and I'd like to adjust the starting engine pinion brake tomorrow, if it is adjustable.
Hopefully one of you experienced guys will advise me on what I must do to get the pinion brake working again. I should say it seems to work just a little
Thank you, Catdan
Thu, Jan 17, 2019 12:48 PM
STEPHEN
Check the oil level, check for wear debris inside, take end plate off for cursory bearing check. When you apply the brake strongly do you hear any change in the rpm?
Thu, Jan 17, 2019 1:24 PM
r4dan
Reply to STEPHEN:
I idle down as low as I can and then try to engage the pinion... when I pull back on the lever to brake the pinion.... I can hear the engine RPM change a little.
Is the clutch dragging?? I was also wondering if that was part of the problem. The clutch snaps in and out fine and holds good cranking the diesel.
Thu, Jan 17, 2019 1:30 PM
Thank you received: 95
Reply to r4dan:
Hi team,
first I would suggest flushing out the pinion housing of old oil and crud, then refill to level with Auto Transmission Fluid and see if you have some improvement.
From memory on the early units the pinion brakes ran a set of discs similar to those used in the pony pinion clutch.
Later units used a tapered cone that ran metal to metal within the rear bearing cage of the pinion shaft.
It is possible some early units were converted to the taper set up.
The other thing that happens is that the clutch discs can flatten out during service and drag causing the brake to loose effectivness.
The linked video by Sasquatch shows how to rectify this.
https://www.youtube.com/watch?v=5Xb9WzUxo5s
As an Apprentice I was shown how to use a 12" steel rule to test each plate for dish and so select the correct sequence of stacking them--Toby shows how to do this.
Hope this helps.
Thu, Jan 17, 2019 5:16 PM
Layne
Send a private message to Layne
Reply to edb:
Hi team,
Hope this helps.
Sorry, I'm new. This might be a dumb question.... What's the reason for not engaging the pinion and leaving it there before starting and while warming up the pony, with the pinion clutch disengaged?
Fri, Jan 18, 2019 2:39 AM
Reply to Layne:
because of the drag of the pinion clutches and pinion gear engaged can be difficult to start the pony --i do exactly what you do and get the pony running and warmed up,shut down. engage and start again
Fri, Jan 18, 2019 3:07 AM
r4dan
Reply to dpendzic:
Thanks for all of the comments guys ... much appreciated.
It does work fine starting the pony, warming it up, killing it, engaging the pinion and restarting the pony, ... just would like to make my cute little D2 work properly !!! LOL
Thanks again !!!
Fri, Jan 18, 2019 3:44 AM
STEPHEN
Reply to Layne:
I have done that many times, sometimes on purpose, but mostly if I had inadvertently killed the pony, or was working through a pony problem resulting in insufficient power, sticky gov, whatever
Fri, Jan 18, 2019 6:44 AM
jstandle
Send a private message to jstandle
Reply to edb:
Hi team,
Hope this helps.
[quote="edb"]Hi team,
[/quote]
I've also seen this suggestion on other threads before, I haven't done it myself but would be the first thing I would try.
Jordan
Fri, Jan 18, 2019 8:22 AM
Thank you received: 289
Reply to jstandle:
[/quote]
Jordan
[quote="jstandle"]I've also seen this suggestion on other threads before, I haven't done it myself but would be the first thing I would try.
Jordan[/quote]
This method has worked for me many times. Inexpensive and simple method. JM
Fri, Jan 18, 2019 8:38 AM
Texasbanton
Send a private message to Texasbanton
Jordan[/quote]
Sounds like your pinion clutches are seized. I'd do the drain, and refill with tranny fluid thing! I'm rebuilding my pinion right now, really easy to do. Just watch Sasquatch's videos on YouTube, explains it thoroughly
1940 212 Diesel Motor Grader 1R565
Fri, Jan 18, 2019 8:50 AM
