D2 - 4U High Idle speed?
Showing 1 to 6 of 6 results
mattD2
Send a private message to mattD2
Can anyone help with the engine high idle setting in a 4U 5831 serial numbered D2?
I have low idle (550rpm) from the service manual, but can not nail down the high idle speed.
Any help appreciated.
Mon, Jun 22, 2009 10:49 AM
bruce oz
Thank you received: 22
hello mattD2, 4U 5831 in my rack settings book (4u5010 to 4u6654)is engine full load rpm 1525 ,engine high idle is 1710 rpm ,rack setting .365 for governor group 5f195 ,governor spring no 5f1940 ,bruce oz
__________________
Mon, Jun 22, 2009 12:08 PM
mattD2
Reply to bruce oz:
__________________
Thanks for the comprehensive infomation Bruce Oz. I was a little lost in tracking this info down.
Thanks for your help and we will see how close we got "by ear"!
Mon, Jun 22, 2009 5:02 PM
SJ
Send a private message to SJ
Reply to mattD2:
Bruce, The rack setting from the Cat rack setting book for that serial number I have from the dealer shows for the specs you give for RPMs and spring # is .285 setting not .365 and that calls for a 9F4113 nozzle and high idle at 1710 and with a 4F4236 nozzle the rack setting is .215 and 1680 high idle. Both settings use the 5F1940 gov. spring as you stated.The full load RPMs is the 1525 RPMs and gives 38 HP for both settings.
Mon, Jun 22, 2009 5:38 PM
bruce oz
Reply to SJ:
hello sj ,my books shows those setting for serial numbers-
4u1-4u5009 ,both sets of specs are issued 12/1956,without having the number of the governor group and spring number we really don't know which info he needs ,
i would go for 38hp instead of 42hp for the setting i posted ,
i looked in my second book and they give different rack setting too for just 4u/5u with no break down of serial numbers for 38hp
???? ,bruce oz
Mon, Jun 22, 2009 6:21 PM
Thank you received: 46
Reply to bruce oz:
???? ,bruce oz
As usual we have variety😊 😊
Mon, Jun 22, 2009 9:53 PM
mattD2
Thanks for all of your responses. Once I pull the Governor off to inspect & reseal I will reference the parts actually fitted to confirm. I think at this stage I will run with the earlier 38hp spec's. Thanks again for your help and advise.
Never ceases to amaze me at the amount of knowledge & literature that is out there for these old girls!
Sat, Jul 4, 2009 5:20 AM
