D2 4J series
D2 4J series
cable control
Send a private message to cable control
I know that there are Caterpillar 3J and 5J D2s. But was there ever a 4J? It doesn't appear in the ACMOC serial number book, but I looked at a wrecked D2 this week and I'm sure the plate was 4J479 SP from memory. Was I seeing things? The owner thought it was a military model. Can the brains trust put my mind at ease?
Wed, Jun 25, 2025 9:49 PM
Thank you received: 279
The U series had a 5U (wide gauge) and 4U (narrow gauge). Was the air cleaner body behind the firewall by the operator or was it at the front right? JM
Thu, Jun 26, 2025 2:50 AM
Thu, Jun 26, 2025 2:53 AM
josh
Thank you received: 13
4J is an R2, same as the J series D2 except it has a gas engine.
Thu, Jun 26, 2025 6:07 AM
cable control
That would explain it. All that was there was from the clutch back, no engine or front components and no track frames.
Sat, Jun 28, 2025 4:21 AM
gauntjoh
Librarian
Thank you received: 5
Hi cable control,
Josh is correct, 4Jxxxx is a narrow gauge R2.
Assuming the plate you mention was on the transmission case, then the tractor has been re-engined with a D3400 engine as used in the J series D2 tractors. If there is a serial number plate on the engine, it may start with 1Sxxxx, which would have been a generator power unit (if my memory serves me correctly).
Here in the UK, many R2 tractors were re-engined in this way.
Sat, Jun 28, 2025 8:21 AM
