D2 3J7XXX fuel filter
Showing 1 to 6 of 6 results
preacherman
Send a private message to preacherman
Help,
Local Cat dealer (Topeka, KS) says he can't get fuel or oil filters for my recently acquired D2. Can anyone point me to a source? Besides the filter any other place I ought to look for cause of no fuel pressure? Have had machine running. Thanks in advance. Preacherman in KS.
Sat, Jun 9, 2007 2:21 AM
Sounds to me like your local parts guy is either to dumb or to lazy to look. Has the oil filter been converted to the full flow cartridge type? If so the current Cat number is a 1R 0659 or go for the Napa/Wix equivalent a # 51161. The Napa/Wix number for the fuel filters is a #33164.
On the no fuel pressure after checking the obvious candidates for pluggage, check the fuel transfer pressure relief (on inlet). They are notorious for deteriorated spring, worn valve/valve seat, or just plain filled with crud.
Sat, Jun 9, 2007 2:52 AM
yieldmap
Send a private message to yieldmap
Just take him the part number and tell him you need 4 fuel filters and 1 oil filter. He'll probably have them in stock.
It's 4 fuel for the 5U D2's, I'm guessing it was the same for the earlier.
Sat, Jun 9, 2007 9:56 AM
Jack
Reply to yieldmap:
D2 5J used three fuel filters. 3J should be the same. Otherwise do everything these guys said. It works for me.😉
Jack
Sat, Jun 9, 2007 12:43 PM
Reply to Jack:
Jack
My local NANPA had the filters for me. 3 in the fuel on the J models. One oil filter. The part numbers listed by others look correct.
drujinin in Elkhorn WI
Sun, Jun 10, 2007 9:39 AM
Craneman
Send a private message to Craneman
Reply to drujinin:
My luck with using aftermarket fuel filters is that I still had to go to the local Cat dealer for the gaskets...the J's filterhead gaskets are different than what was sent.
Sun, Jun 10, 2007 8:14 PM
gemdozer
Thank you received: 12
Reply to Craneman:
the CATERPILLAR d2 use fuel filter7b8262 and oil filter 9f6700 and still have some new one
Mon, Jun 11, 2007 4:04 AM
