D2 3j3054
D2 3j3054
Nick22australia
Send a private message to Nick22australia
Hi all, I was wondering if anybody could tell me the exact part numbers of the front timing gear housings and the radiator mount that bolts to the bottom of them for my machine?
Maybe also the sprocket seals as well, was checking over this machine in greater depth the other day and found the right final drive full of grease,must have been leaking badly as it still drives fine through both tracks
Thanks again
Mon, Sep 3, 2018 7:56 AM
Mike Meyer
Thank you received: 6
Radiator support bracket 4B7458
Front timing case "Housing" 4B5038
Front timing case "Cover" 4B5547
Rear bellow seal 3B5762
Good luck
Mike
Mon, Sep 3, 2018 1:53 PM
Nick22australia
Reply to Mike Meyer:
Good luck
Mike
That’s awesome,thanks mate
This poor thing has had a blade on it and the blade cylinders attached to a scrub canopy which was fixed to the body of the machine so I’m not sure if that’s how it all got broken??
the radiator mount was hacked away with an oxy but both parts of the timing gear housing have had dodgy repair jobs so to do it properly I’m going to need parts
It’s had a hard life but I’ll get it sorted
Mon, Sep 3, 2018 3:07 PM
Mike Meyer
Reply to Nick22australia:
There will be a wreck 3J or 5J somewhere in Oz you can get parts off, if not there will definitely be parts in the USA.
Mike
Tue, Sep 4, 2018 3:35 AM
Nick22australia
Mike
Waiting to hear back from a wrecker down south in wa, they have them but not sure if it’s for a 3j
I understand the mounts changed at some point, maybe if they had the cases and the mount for a later one I could change it all to that ???
Tue, Sep 4, 2018 1:15 PM
| Kingaroy, Queensland
