D2 3J Water Pump Overhall
DaveImrie
Send a private message to DaveImrie
Hi Guys
I've stripped my water pump down after finding a leak on the shaft where the threaded seal housing screws in. After taking it to pieces, i found that the old packing seal was toast. The shaft is pretty worn too but that should not be too much of an issue. Where can i find this seal or a length of packing, but not the length of a D2, i only need a few cm worth.
Dave
CAT D2 3J472, CAT D2 4U1902, CAT RD4 4G7338 & 4G7339, Wolsley Stationery Engines, Onan W2S Genset
Wed, Mar 20, 2013 8:48 PM
Ask at any industrial supply company or pump service shop. The square "rope" packing is commonly used in industrial pumps. There are various sizes (the "square" dimension) and differing lubricating compounds available. Graphite is common, also teflon, possibly others are available.
Take note that the lubricant that ultimately keeps the packing from getting hot is coolant. The packing should be tightened so that it does not leak "too much"πŸ˜† It's hard to keep one totally dry when you stop the engine and also have it stay cool while running. Probably will have to put up with a little seepage with it stopped or it will get hot while running. If it gets hot, it will wear the packing quite rapidly compared to if you keep it adjusted properly.
Adjust it slowly with the engine running, you want to let it drip some initially and only tighten the gland nut enough to stop excessive leakage. If you tigten it when you stop the engine, then plan on loosening it again when running, possibly while the pony motor warms the main engine up.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare timeπŸ˜„
Wed, Mar 20, 2013 10:13 PM
STEPHEN
Try mcmaster.com
Thu, Mar 21, 2013 3:46 AM
Reply to STEPHEN:
Try mcmaster.com
If you are not near a large town or city plus find it hard to order small orders. I would recommend junk yards for large gate valvles where they would let you remove the packing from the stem as they are probably scrapping anyways.
Or a farm tractor supply, automotive type of shop or a boat yard.
Just throwing you some options!
Thu, Mar 21, 2013 5:03 AM
Jack
Reply to drujinin:
Setting the packing nut on a J series while running is a good way to get your knobby nuckles smoothed off real nice, or get your wrench stuck through the radiator, or see your hand set a speed record for passage around the governor housing with the fan... There's a lot of possible ways to be a candidate for a Darwin award here. Take a guess and run it a while. When you shut it off, take another guess if it's leaking, or if it's not, and isn't hot, your first guess was a good one. It's closer than it looks in there.
Fri, Mar 22, 2013 8:46 AM
