D2 3J rail height
D2 3J rail height
scarter
Send a private message to scarter
Does anyone know what the acceptable rail height is on a D2 3J, maybe new vs 100% worn? Also how many links were are supossed to be on a new set of chains?
Thanks,
scarter
Sat, Jan 8, 2011 3:18 AM
Hi scarter,
my only D2 data tells me that new height is 3" and, 100% worn is 2.75" for 5B3129 Links.
Hope this helps,
Sat, Jan 8, 2011 5:49 AM
small idler uses 30 links
large idler (23 1/2" OD) uses 31 links
5 roller track frame (large idlers only) uses 35 links.
Sat, Jan 8, 2011 9:35 AM
the Farmer3
Send a private message to the Farmer3
look at wear limit guide http://www.crawlerheaven.com/index.htm
Sat, Jan 8, 2011 7:11 PM
scarter
Reply to the Farmer3:
Ok......well my rails are 100% worn at 2.75 inches. My sprokets are good and front idlers need some minor attention which I will address. My rollers are worn, and I am in the process of welding them up back to spec. I found brand new 30 link rails for $1421.82, which I am going to get headed my way very shortly. While I am waiting on the new rails to get here, would it be a good idea to go ahead and put everything back together after idler and roller repair and run it a little bit to smooth things out a little before installing the new rails?
Any input would be helpful.
Thanks,
scarter
Mon, Jan 10, 2011 10:26 PM
