D2 3J donkey engine
D2 3J donkey engine
Showing 1 to 7 of 7 results
caterpillarsam
Send a private message to caterpillarsam
Hello again all
Got another joyful question for you,
I have had my crankshaft ground so I’m of course going to use undersize bearings
BUT
do I also need to use undersize crankshaft seals?
If so I will need part numbers etc
On a side note, I imagine I am not the only one looking forward to watching squatch253 start building a donkey engine for his 5J
Sat, May 30, 2020 3:43 AM
Great question - when I did both of mine (5U and 3J pony engines), I didn't think about the seal size so I'm glad you pulled up this question. Mine are 030 I think but they don't leak and have the standard Cat part # seals in them
Sat, May 30, 2020 5:13 AM
caterpillarsam
Hmm interesting, i will definitely make a note of that.
Hopefully someone on this group will be able to shed more light on the topic
Are the U donkeys any different to the J donkeys? Obviously things like electric start
Sat, May 30, 2020 5:33 AM
Fat Dan
Reply to caterpillarsam:
Thanks great info to know
Sat, May 30, 2020 7:52 AM
BillWalter
Reply to Fat Dan:
Take the spring out of seal, unwind the spring, cut off a couple of rounds of seal, then screw the seal back together. This will tighten the seal around the shaft a little tighter.
Sat, May 30, 2020 9:08 AM
Mike Meyer
Reply to Fat Dan:
Exact same basic donkey motor, just subtle changes to the bolt on stuff like upper manifold and heads over the years and models, none of the Parts Number books lists a seal for undersize cranks to go with the undersize bearings, so I assume Cat didn't think it necessary.
If you were running the pilot motor 8 hours a day I'd be concerned, but generally they are lucky to run 15 minutes max, most times 5 minutes, can't figure much oil could be lost in that time past the seals.
Sat, May 30, 2020 9:12 AM
Reply to Mike Meyer:
I agree Mike. I have not put any oil in my ponies since the initial set of runs after rebuilding (first start, flush, couple of runs, another flush and done) and they're about halfway down the stick. I can't see any leakage on the flywheel end seal. Who knows about the other end but the pinion chamber has not gone up at least.
Sat, May 30, 2020 8:58 PM
restore49
Somewhere I have a book with seal sizes .
Sat, May 30, 2020 9:32 PM
