D2 3j donkey
D2 3j donkey
caterpillarsam
Send a private message to caterpillarsam
Hi all
I’m after the part numbers for the two 20thou undersize crankshaft bearings in my D2 3j donkey engine.
Thanks in advance
Wed, May 20, 2020 5:27 PM
My parts book has
8b6 rear (Next to flywheel)
8b5 front
Wed, May 20, 2020 6:57 PM
caterpillarsam
My parts book has
8b5 front
[quote="ccjersey"]My parts book has
8b5 front[/quote]
Yh I have that in my book as well, however it’s not a compatible part number that cat recognises if that makes sense, I need the updated part number
Wed, May 20, 2020 7:06 PM
Reply to caterpillarsam:
8b5 front[/quote]
I have 3B7980 for flywheel bearing and 3B7979 for front of tractor bearing, and 2A3435 for the dowel (2 required). These numbers are for 3J1 through 3J4877. Then it changes to 8B6 which would be 8B0006 in Cat's system for the flywheel end and 8B0005 for the front of tractor. Dowel part # is unchanged
Wed, May 20, 2020 8:00 PM
caterpillarsam
Thank you all, so handy you guys all helping me out
Thu, May 21, 2020 6:07 PM
mog5858
if you can't find them they are really quite simple to make with a lathe. as the are just 6060 AL. just add your oil clearance to whatever you got you crank ground too.
Sat, May 23, 2020 10:55 PM
