D2 13XXX Hyd Cyl 8F2657
flmore
Send a private message to flmore
Would like to know what the piston retaining nut torque is? The one that I opened up was less than finger tight. Also would like to know an after market sorce for cutting edges. Need corner bits and edges for both a 2S and a 2A.
Thanks Floyd
Fri, Mar 6, 2009 1:31 AM
Never have seen a torque chart for hydraulic piston rod nuts. I just get them as tight as you can....I clamp mine in my big hydraulic press and swing on the end of a 5-6 ft cheater on the breaker bar or rattle away with the one inch drive hydraulic impact wrench. Don't forget the lock tabs.
I don't recognize that number....is it a casting number or part number?
Fri, Mar 6, 2009 8:02 AM
flmore
That is the casting number. I also have a set of old style cyl that have a hex nut. I tightened them as tight as I could. The newer style have a diffrent type nut. It is round with 2 flats cut in it and don't provide much to get ahold of, locked with a cotter key. The piston is long with three composit rings that install like a engine piston ring. The piston is prevented from rotating by a key. The by-pass is controled with 2 valves built into the piston. Is it possable that the piston is designed to float?
Fri, Mar 6, 2009 8:30 AM
Reply to flmore:
That would be this style of cylinder.....see what you mean on the retainer nut....about the only way you'd get a good grip on the two flats would be a special socket. I wonder if it could be replaced with a conventional hex or jamb nut and cotter pin.
Not sure what you mean by float......if on the rod, no.....in the cylinder, yes.
Fri, Mar 6, 2009 9:35 AM
flmore
By float, The piston floating on both the cyl and rod. I think I will make a socket out of plate to fit the nut. With the cyl keyed to the rod it should not take much to hold it.
Thanks Old magnet, You are a blessing to all of us. I know that sometimes answering the same question over and over gets old but you always come thru.
Thanks again Floyd
P.S. I did file the thumbnail to my D2 files
Fri, Mar 6, 2009 10:58 AM
