D17000 gensrt
D17000 gensrt
Showing 1 to 6 of 6 results
hfdzl
Was there ever a direct electric start version of this machine. Not electric start pony. Or a flywheel housing that would fit from another machine?
Fri, Feb 17, 2023 11:54 PM
josh
Thank you received: 6
Short answer is, yes there was electric start available, but it’s different, it used a pinion assembly like a gasoline starting motor, but powered by a gear drive electric motor, also available was a similar unit called a stall starter, pictures from parts book later.
Sat, Feb 18, 2023 4:17 AM
hfdzl
Reply to josh:
Thanks Josh. Waiting for pictures
Sat, Feb 18, 2023 5:15 AM
Thank you received: 19
Reply to hfdzl:
Looks like an air starter was also available.
Sat, Feb 18, 2023 5:33 AM
josh
Here is one example of the starter assembly, there may be slightly different ones depending on the SN, you can give me the number and I can see if I have that book, if it matters.
Sat, Feb 18, 2023 9:08 AM
hfdzl
Reply to josh:
Yes, that also in the 2V book. Chances of actually finding these parts I believe would be just are they are , a dream. Thanks to all for helping!
Herb
Sat, Feb 18, 2023 10:11 AM
josh
Reply to hfdzl:
Herb
A note, the electric starter was 32V.
Sat, Feb 18, 2023 10:49 AM
