D13000 question
D13000 question
Showing 1 to 10 of 22 results
lil cat mec
Send a private message to lil cat mec
Howdy all, ive got a D13000 serial 4s8806 I've been measing with. Its powering a chicago pneumatic 4 cylinder compressor. Ive got the pony running great, the main engine seems to only hit on 5 till its under load and evens out.. anyways yesterday i fired it up and it didnt register any oil pressure (it did about a month ago ladt time i fired it up) where is the oil pump located on it, at work we have a parts microfiche but it doesnt show a location.
Hope everyone is doing good
Dalton..
1935 CAT 22 2F4455W
1990 CAT D6H 4GG04120
2012 CAT 272C RED02823
1971? CAT 951B 86J01212
Thu, Apr 20, 2017 5:30 AM
gemdozer
Thank you received: 25
The oil pump is in the pan and you have to removed the inspection pan side plate for checking
Thu, Apr 20, 2017 6:34 AM
lil cat mec
Reply to gemdozer:
Okay, i guess my question was pretty broad, i meant under the front or rear inspection cover. I got found a couple more microfiche and it seems to be under the rear inspection cover.
Sorry im not use to looking through microfiche's and must have skimmed over it a couple dozen times and got frustrated! Ill post up a video once shes going!
1935 CAT 22 2F4455W
Thu, Apr 20, 2017 7:55 AM
Andrew
Reply to lil cat mec:
Check the gauge first.
The oil pumps are very reliable and not prone to failure.
Thu, Apr 20, 2017 1:03 PM
mrsmackpaul
Reply to Andrew:
perhaps try and unscrew the pipe off the gauge or the block is easier and see if its pumping oil at all
Paul
Thu, Apr 20, 2017 1:53 PM
ag-mike
Reply to mrsmackpaul:
Paul
theres only 2oil pan side covers. the right side will give u closest access to the pump. the left side gives u best access to clean out sludge.
Thu, Apr 20, 2017 8:27 PM
lil cat mec
Reply to ag-mike:
There are two covers on the right hand side. I did unscrew the oil line going to the gauge and there was no flow. It is possible the something plugged the line. This saturday i think ill go back over there and pull a cover and see what she looks like.
1935 CAT 22 2F4455W
Fri, Apr 21, 2017 12:22 AM
ag-mike
sludge plugged pump screen.
Fri, Apr 21, 2017 1:25 AM
STEPHEN
Reply to ag-mike:
Even after you sort out the oil problem, I recommend turning the engine over with no compression and checking oil pressure before starting. If you don't want to destroy your engine.
Fri, Apr 21, 2017 4:14 AM
old-iron-habit
Reply to STEPHEN:
Well said. A good habit to be in with any Cat engine. So easy to do with the pony motor. I also hold the compression release out until I get oil pressure on my 335 Cummins in the old Kenworth.
Fri, Apr 21, 2017 5:08 AM
Thank you received: 78
Reply to old-iron-habit:
Ah small cam 335 - takes me back...
Fri, Apr 21, 2017 5:10 AM
