D13000 Hotstart Install
Showing 1 to 7 of 7 results
cjrampley
Send a private message to cjrampley
Has anyone successfully installed a Hotstart coolant heater in a D13000? I would like to install one in my 1939 Cat, in a marine application. It would keep the engine room warm and dry and prolong the engine life. There is already a lot of galvanic protection built into the cooling loop. The zincs get changed regularly, and the system is cooled through a raw-water heat exchanger.
Any reasons I should not do this? Things to consider? The boat is normally at the dock with 30 amp 110 power, and will start at anchor with just the pony.
Thanks for any advice given.
Chris
Tue, Nov 15, 2016 10:44 AM
Thank you received: 19
Can't think of any reason not to, just a matter of making connections that will provide good thermo syphon operation.
Tue, Nov 15, 2016 12:24 PM
Thank you received: 23
Not sure if this is applicable but one thing to consider is finding a way to minimize heating the raw water if running costs are a concern
Tue, Nov 15, 2016 7:12 PM
cjrampley
Do you think tapping into the lines where the coolant enters from the pony loop would be a good place?
Wed, Nov 16, 2016 11:53 AM
Reply to cjrampley:
The lower pony motor cooling connection would be good but I would look for the upper connection to be at a higher elevation like maybe at or around the thermostat housing.
Thu, Nov 17, 2016 1:12 AM
biggastractor
Is this going to be on the raw water side? If so, make sure all connections are double clamped and if possible above the water line so any break or leaks wont flood the bilge. Loops in the hoses would be a good idea too. Does AYBC have a standard on this?
Good Luck
Biggastractor
Fri, Nov 18, 2016 9:19 AM
cjrampley
Reply to biggastractor:
Good Luck
Biggastractor
[quote="biggastractor"]Is this going to be on the raw water side? If so, make sure all connections are double clamped and if possible above the water line so any break or leaks wont flood the bilge. Loops in the hoses would be a good idea too. Does AYBC have a standard on this?
Good Luck
Biggastractor[/quote]
This will be on the engine coolant side. The systems join in a big heat exchanger. The raw water intake is a 2" hard-plumbed line, and I always shut the thru-hull valve unless the engine is running. There are AYBC standards on this, but they were developed long after the engine was installed in 1939. You ask good questions, though luckily most of my plumbing is heavy bronze and the few rubber lines are all double stainless clamped. One of the nice things about having a real engine room is you can readily access and visually inspect almost everything. I'm used to working upside down on engines stuffed under the cabin floor boards. With the D13000 I can sit on a bucket next to the engine and work on it at eye level. It's a nice change.
Fri, Nov 18, 2016 8:29 PM
biggastractor
Reply to cjrampley:
Good Luck
cjrampley,
I used to own a marina and understand exactly. Good luck with your project.
Biggastractor
Fri, Nov 18, 2016 10:38 PM
