D13000 Engine Bearings
Showing 1 to 10 of 11 results
Jeremy Williams
Send a private message to Jeremy Williams
Hello All,
I bought a reground crankshaft for my RD-8. I am looking for the part numbers for rod and main bearings that are .025" undersize. My parts book only shows standard and .050". Any help is appreciated.
Thanks,
Jeremy
Wed, Nov 23, 2016 11:43 PM
Clevite number for the rod bearings is CB817 (10-20-25-50) undersizes
Clevite number for the main set is MS455AL (10-25-50) undersizes.
Plug those numbers into a parts search on www.machinerytrader.com or internet search.
Thu, Nov 24, 2016 12:16 AM
Jeremy Williams
Thanks OM! Do you happen to know if all of the main bearings are the same width? For some reason I thought that the front and rear ones were wider.
Jeremy
Thu, Nov 24, 2016 6:12 AM
brian18a
Online
Thank you received: 70
Reply to Jeremy Williams:
Jeremy
What serial number is the engine? If early, need different bearings than what OM stated, early have shimmed bearings.
All main bearings are different length dependent on position.
Thu, Nov 24, 2016 7:18 AM
Jeremy Williams
Reply to brian18a:
Brian,
The engine number is 1H10xx. I have been told that the tractor should have originally had Babbitt bearings, but this one has aluminum inserts.
I was able to google the number for the mains OM gave me, and came up with MS1048AL, MB2585AL, and MB2586AL(F). Here is the link (the D13000 is on page 165). http://www.mahle-aftermarket.com/media/local-media-north-america/pdfs/eb-10-07.pdf
Jeremy
Thu, Nov 24, 2016 7:44 AM
brian18a
Online
Brian,
Jeremy
Yes it would have had babbit bearings with shims. I guess it is possible to make aluminum ones work, but if they were not shim type, it would have required modifications to make spacers to replace the shims. Spacers would be needed to prevent crushing of the aluminum bearings. As the babbit design, the shims spaced the two halfs of the bearing and also spaced the bearing cap from block.
Looking at the clevite listing, I believe it is for much later engine. Note the bearing wall thickness is 0.172. Bearing thickness in the older D13000 is much thicker. Also says no 4 is flanged, the old D13000 did not have thrust bearing, thrust is taken up by thrust plate behind timing gear. And listing shows No 1, 2,3,5,6,7 are all same bearing, that is not right either.
Early D13000 should have one front main, four intermediate main, one center main, one rear main, and the rear oil control bearing cap.
I think the number OM gave would be thick wall bearings, which probably clevite does not make anymore.
So your engine has gear drive fan? If so I hope your crank is for that style. Not easy finding gear drive fan cranks.
Thu, Nov 24, 2016 10:50 AM
Reply to brian18a:
More info....
CB817AL (1H1-up) Heavy duty shimless type bearings 0.1691" thick, 2.563" long
MS455AL (1H6237-up) Aluminum bearings with syntech type rear oil seal
Made up of:
1-MB1138AL (0.4341" thick x 2.578" long)
1-MB1140AL (0.4341" thick x 4.156" long)
4-MB1139AL (0.4341" thick x 1.781" long)
1-MB1837AL (0.4341" thick x 4.078" long with 0.4320 Aft End)
For Crank Forging:
2B6488
3B7934
3B7937
3B9511
7B7937
7B9511
7B9620
4F8511
6F1913
4H7032
My Federal Mogul catalog shows early series engines using bronze back main bearing set #725M in 20-30-50 & 75 undersizes, consisting of:
1- #1596B
1- #1597B
4- #1958B
1- #1599B
Set replaces Cat # 7B9164, 2F0501
Very early Bronze-Back, shim type bearings not available.
Thu, Nov 24, 2016 11:20 AM
brian18a
Online
More info....
Made up of:
For Crank Forging:
2B6488
3B7934
3B7937
3B9511
7B7937
7B9511
7B9620
4F8511
6F1913
4H7032
1- #1596B
1- #1597B
4- #1958B
1- #1599B
Another thing is to determine block casting number. Cat made replacement blocks that were precision blocks, did not use shimmed bearings. And the later bearing OM listed fit these.
Thu, Nov 24, 2016 12:22 PM
Jeremy Williams
Reply to brian18a:
I will have to look at the forging number on the crankshaft next time I get a chance. I don't know what the block number is, but it has the same brass tag as the rear end, so I assume that it is original.
The crankshaft does have the gear for the fan drive. I have been patiently waiting for 10 years to find a new crankshaft for the ole' girl.
Again, thanks for all the help gentlemen.
Jeremy
Fri, Nov 25, 2016 6:16 AM
brian18a
Online
Jeremy
Hopefully original engine. One of my replacement blocks, has the brass tag from original engine. That should have helped confuse anyone wanting parts.
Fri, Nov 25, 2016 7:37 AM
Andrew
Reply to brian18a:
When I put the engine together in the RD8 I have here I used later non shim conrods.
Can't remember what I did with the mains.
Fri, Nov 25, 2016 8:44 AM
