D13000
charles poole
Send a private message to charles poole
Hi all , can anyone give me the flywheel to crank bolt torque specs for a 13000 engine ? thanks,
Charles
Mon, Jun 9, 2008 12:56 AM
SJ
Send a private message to SJ
Just get a torque sheet and check the size bolt and go by that torque on the sheet. If I remember right they are a 3/4" bolt so 225 lbs. torque would be good if they are 3/4" but check the diameter anyway to be sure.Go to that torque and advance enough so the lock bend overs line up ok.
Mon, Jun 9, 2008 2:06 AM
charles poole
Reply to SJ:
thanks SJ , will talk to you soon ,
regards ,
Charles
Mon, Jun 9, 2008 6:27 AM
Thank you received: 25
Reply to charles poole:
regards ,
Charles
Hi Charles,
This may be coming at you a little late but here's the chart on standard bolt torques.
Mon, Jun 9, 2008 11:12 AM
