D13000
Showing 1 to 10 of 24 results
charles poole
Send a private message to charles poole
Ol magnet , If you read this post , could you possibly give me any information you might have , I have a D13000 power unit serail # 4s13531 , bill of matl #
9B2998 , If you could even give me the year of this engine iI would appreciate it !! thanks , charles poole
Thu, Jul 12, 2007 7:10 AM
Thank you received: 24
Looks to be at the end of the 4S series.
I show 13,279 - up and 1953 production.
I have the Operator's Instructions manual 4S1001 - up Diesel Engine and Electric Set but not the Parts Manual.
What information are you looking for?
Thu, Jul 12, 2007 7:26 AM
SJ
Send a private message to SJ
As far as horse power there are so many settings for this engine that the RPMs & the rack setting would have to be determined to even establish what it is. My old Cat fuel injection book has a 1/2 page of different settings for that particular engine. AS far as a parts book the old D8 2U tractor had the same basic engine so most parts are all the same except a few minor differences.
Thu, Jul 12, 2007 10:44 PM
charles poole
Reply to SJ:
Thank you , ol magnet & SJ the two of you seem to be the men to go to when
it comes to these motors , I will be communicating with the two of you soon , maybe with some pictures , thanks again chas !!!
Fri, Jul 13, 2007 7:33 AM
charles poole
In addition to restoring a 38 b shovel with a caterpillar engine , I am also restoring a unit model 614 cable backhoe ,with a 2-71 detroit , I have completely rebuilt the engine , But now I am having trouble locating drive chains
they are 3 .25 inch pitch roller , does anyone out there have any idea where I might locate some ?? Thanks , chas
Sun, Jul 15, 2007 9:49 PM
SJ
Reply to charles poole:
You could give this place a call & see if they can help you or steer you to a place. It,s Bearings & Drives Unlimited, 1568 Highway 315 Wilkes Barre Pa. Ph. (570) 822-7196
Sun, Jul 15, 2007 11:28 PM
Craneman
Send a private message to Craneman
Reply to SJ:
Try Roland Machinery at 800-765-2635 and tell them that you want Ray Heffernaum to contact you. Roland Machinery is a Komatsu Dealer but they also sell Pyramid Parts. Pyramid crane chain cost a little more than the competitors but it's the best drive chain made..it's built heavier/beefier than than anybody elses. Once Pyramid chain is installed they'll be no more breaking pins or links.
Mon, Jul 16, 2007 12:21 AM
charles poole
Reply to Craneman:
Thanks SJ ,and craneman , I appreciate the info !!
Thanks again , Chas
Mon, Jul 16, 2007 5:41 AM
charles poole
Hi all , Brought my engine into a shop where i can work on it at night or during
bad weather , I had pulled the heads off this engine last summer while it was still in the shovel , I thought that I just had a stuck engine caused by water going down the exhaust , As it turns out there is a little more to it than that !!
I disconnected 3 connecting rods and pulled 3 sleeves pistons intact ,
Apparently someone had tried to turn this engine over with I believe water in cylinder As I found # 4 con rod severely bent ,and about a two inch chip out of the bottom of the sleeve ,the good news is the crank journals appear to be OK ,
I will try to pull the remaining 3 tomorrow .
I am starting to think I know how paso chris feels !!
Tue, Jul 24, 2007 5:10 AM
Three down and three to go😄 😄 Not bad so far....hope Chris is observing cause he's about to face the same issues (less bent rod I hope)
Please share your techniques😊 😊
Tue, Jul 24, 2007 5:48 AM
charles poole
OM , how ya doin , I have been following chris post with great interest ,I read where you told him about the rear main seal being a weak link , so far my bottom end appears to have been under clean oil , in respect to the oil pump & scavenger bell , should I worry about the seal ? or should at this point I pull the flywheel & harmonic Bal , and replace the seals ? I am still going to try to post some pics , I am a better mechanic than a computer operator , Ha ha
OM , I am not sure you want me to post my tecniques , as I made a puller out of plate steel , and welded a center into the sleeves , pulling off of the head bolt studs , My feelings were the sleeves are shot anyway , A whole lot of Barnyard , But it worked for me . Regards , Chas
Tue, Jul 24, 2007 7:05 AM
