D-17000 sensors/gauges
PRR 9339
Send a private message to PRR 9339
I recieved my "renual parts catalog" and found 2 gauges I would like to replace. The book has a tendancy to say cat. for either Caterpillar or catalog number.
Do any of these part numbers sound normal
Lube Oil
receiver unit cat. 6729122p1
sending unit cat. 6729122p2
Water Temp.
Receiver unit cat.6729121p1
Sending unit, cat.6729121p2
Sound familar? I look at a unit with modern gauges but the 72v system is always a factor.
Jamie
Sat, Feb 18, 2012 4:51 AM
Thank you received: 20
Those don't look like any Cat numbers I've seen....more likely catalog numbers as you say.
Sat, Feb 18, 2012 8:30 AM
dmooney8
Send a private message to dmooney8
We have a 1947 loco with 2-D17000 engines w/documentation.
The numbers that you quoted are indeed Caterpillar numbers.
Have you been able to find the oil pressure gauges??
Thu, Jun 14, 2012 12:23 AM
