Cutting edge part numbers
Showing 1 to 10 of 13 results
1972RedNeck
Send a private message to 1972RedNeck
9S blade 53C serial number. Need current part numbers for the cutting edge and corner bits. 1J0019 doesn't cross to anything on Cat's online parts catalog.
Looking for the thickest and heaviest available. Don't care if the cutting edge is one piece or multi piece.
Thu, Dec 19, 2024 10:53 PM
seiscat
Cutting edge 1-5/8 thick is 2 piece 7J2962. End bits are 1-5/8 7J3461-2 or forged 5J1279-80
Craig
Fri, Dec 20, 2024 3:22 AM
1972RedNeck
Reply to seiscat:
Craig
I appreciate it, but the corner bits are most definitely left and right specific. That chart only has one part number listed...
Fri, Dec 20, 2024 8:35 AM
seiscat
Reply to 1972RedNeck:
You don't know how to read the part numbers. The end bits are 7J3461 AND 7J3462 and the forged ones 5J1279 AND 5J1280!
Fri, Dec 20, 2024 9:57 AM
seiscat
Reply to seiscat:
Odd numbers are for the left side, even numbers are for the right.
Craig
Fri, Dec 20, 2024 10:31 AM
seiscat
Reply to seiscat:
Craig
I hope you found the proper numbers. My last responses were short and didn't explain why the part numbers are listed in this manner.
Caterpillar provided customers with the "One Safe Source" catalogs for free. They tried to condense everything to conserve space.
I don't usually respond to posts from my telephone as I try to use the fewest words possible. I hope I wasn't too abrupt.
Craig
Fri, Dec 20, 2024 9:39 PM
1972RedNeck
Reply to seiscat:
Craig
Not at all. I appreciate the help. I was confused by dashed part numbers as that's not how Cat does part numbers. It all makes sense now.
Thank you for the help
Fri, Dec 20, 2024 11:15 PM
josh
Thank you received: 14
1J19 crosses to 5J6802, which is a cutting edge consisting of, one 5J6800 and two 5J6806, used on the 53C and 21E.
Sat, Dec 21, 2024 12:18 AM
seiscat
Reply to josh:
The thicker version (1-5/8") of that 5J6802 is the 7J2961 (center) and 7J2960 (2 ends)
Craig
Sat, Dec 21, 2024 12:44 AM
Busso20
Thank you received: 31
Reply to seiscat:
Craig
Seiscat, I never knew odds left even is right, thank you Ill remember that one
Sat, Dec 21, 2024 6:58 AM
bluox
Reply to Busso20:
They are not always some left odd or even ,right can be odd or even.
 Bob
Sun, Dec 22, 2024 1:15 AM
