Cutting edge part number
Showing 1 to 10 of 10 results
wibbdog
Send a private message to wibbdog
I have a d68u. 10835 serial number on the tractor
I am looking for a part numbers for the cutting edges on the blade there is the center and the two ends
The tag riveted to the blade is 15C1888.
Or maybe it's not available anymore
D4 7U 36840
Tue, Oct 18, 2016 9:56 PM
RH end bit 1J0129
LH end bit 1J0130
Center cutting edge 1J0015
Tue, Oct 18, 2016 10:51 PM
seiscat
RH end bit 1J0129
LH end bit 1J0130
Also available for your blade are the heavy duty end bits 9F7073 (R.H.) and 9F7074 (L.H.). The 1J0129 and 1J0130 are the standard flat plate end bits. The heavy duty end bits last much longer.
The 30 bolts and nuts required for these end bits and cutting edges are 3F5109 bolt and 1D4720 nut.
Your blade is part of the 8F8907 Blade Group – Serial Numbers 15C1860 to 15C1899 inclusive.
Happy Dozin' :cool2:
Craig
Wed, Oct 19, 2016 12:15 AM
Reply to seiscat:
Craig
My parts book does not show the HD end bits as being applicable until blade s/n 15C1900-up group 2J8579.
Wed, Oct 19, 2016 2:15 AM
wibbdog
Wow ! Thanks so much
D4 7U 36840
Wed, Oct 19, 2016 2:19 AM
seiscat
Reply to wibbdog:
The 2J8579 Blade group also uses the 1J0129 and 1J0130 standard end bits and lists the 9F7073 and 9F7074 optional heavy duty end bits ergo the heavy duty bits will also fit the 8F8907 Blade Group.
Wed, Oct 19, 2016 3:46 AM
Reply to seiscat:
Again, not what my parts book says. Form #UE033684
2J8579 group uses standard 5J6923 RH bit, a 5J6924 LH bit and a 5J6879 cutting edge for 15C1900-up. I don't have info on interchange.
Wed, Oct 19, 2016 4:43 AM
Current part numbers for 15C1-5000 are 3G8321/2 or 9F7073/4 for "contoured" end bits (considered heavy duty) or 4T3951/2 for standard (straight) end bits. So yes, they do interchange.
Current cutting edge is a 4T3021
Wed, Oct 19, 2016 4:55 AM
Sure that wasn't 3F5108 bolt? Torque is 200+- 30 ft lbs. tighten from one end of the edge to the other or from the middle and work out to the end. Tap each bolt with a heavy hammer and re torque.
Wed, Oct 19, 2016 6:08 AM
seiscat
You caught me in a typo Rome/KG you are correct - bolt should be 3F3108. I hate it when that happens. Thanks for the heads up. wibbdog there is a lot of help available here, but sometimes it is better to to let the dust settle before ordering parts, sorry 'bout that.
Craig :redface:
Wed, Oct 19, 2016 9:00 AM
wibbdog
Reply to seiscat:
Craig :redface:
Again thanks.
This group has helped me with many things on my d4
I was able to find all three pieces. Well they are coming from three different locations
This d6 is new to me
D4 7U 36840
Wed, Oct 19, 2016 11:07 PM
