CT-4 magneto troubles.
thomas84
Send a private message to thomas84
I'm trying to get spark out of my mag that's bee sitting for years, I clean up the points, every thing else looks clean. When I roll it over bs snap the impulse I on have spark between the points every once in a while. Why don't I have it all the time? Connections look good and clean. Is it the condenser? Or..? Thanks in advance.
Tue, Jun 23, 2015 8:23 AM
tailseat15
Send a private message to tailseat15
The condenser can be checked by a mag shop. I don't know how to field test except by trading with another known good unit.
Are the bearings greased and in good shape so the gears turn well/easy?
Tue, Jun 23, 2015 8:37 AM
Lance Jones
Reply to tailseat15:
First Check Those points again , Make sure they are absolutely Clean and set to 20 Thou , I use a can of CRC Electra Clean for doing this Work. Condenser sounds Most likely Your problem ,Do You have a Bright Blue Spark [ Needed ]or a Orange Type spark ? I have not been able find Condensers that fit the CM4/ CT4 ,But I have had 2 repacked and with Excellent Results . If condenser is OK then Next Suggest removing External Magnet at Check That . My test is to try and Pickup a medium size chisel or Spanner . If it is weak then Get it Recharged , and lastly if all else Fails remove Coil and have it Tested , May need a rewind .Someone able to do that Work Out here is a Bit had to Find , One Chap who did excellent Work passed on Recently .
If you can't get to a test Bench , Remove Impulse [you need a rattle gun to remove Nut ] and Put mag in a Vise and Hook a Drill onto shaft and Spin it over with a wire earthing to Vise. Hope this Helps you sort your Problem out . LJ
Wed, Jun 24, 2015 11:43 PM
ag-mike
Reply to Lance Jones:
look real close at the cam the points cam follower rides on that it ain't pitted and wearing down the bakelite thus changing ur points gap.
Thu, Jun 25, 2015 12:55 AM
Steve A
Reply to ag-mike:
condensers go bed over time, they can be purchased through most auto parts that order from standard electric. Not sure about the size as far as fit up.
If all else fails Roys magneto service in Mt pleasant is where mine go.
Thu, Jun 25, 2015 4:01 AM
thomas84
Reply to Steve A:
Thanks a lot guys, I will try to figure it out this weekend. Good to know there is a mag. shop 2hrs from home, thanks Steve. Not very many shops around that will fix alternators and starters let alone a mag.
Sat, Jun 27, 2015 7:28 AM
