Cover gasket help
Cover gasket help
Showing 1 to 10 of 10 results
kracked1
Have the parts book but cant figure out the part number for the transmission cover gasket. It is a single piece cover D47U. Any help would be great.
Thu, Jul 21, 2022 3:52 AM
rax200
Hi kracked1,
The gasket you are after is 3b0889 and 2 required, but sit down when Cat tell you the price. I now use a length of 3/8 o ring material as it was much cheaper.
Regards
Thu, Jul 21, 2022 7:40 AM
Thank you received: 55
Reply to rax200:
Hi kracked1,
Regards
any thing that is a oring groove seal its cheaper to buy a length of the appropriate size nitrile o-ring stock and make your own. bond it using loctite 406 adhesive or loctite 480 rubber toughend adhesive. both are available through most good industrial suppliers or bearing suppliers. many workshops dont stock premade orings any more and use kits to make what they need as its cheaper.
Thu, Jul 21, 2022 1:31 PM
kracked1
Reply to trainzkid88:
Thank you so much.
Thu, Jul 21, 2022 3:30 PM
willwingo
Thank you received: 8
Reply to kracked1:
Thank you so much.
The information above is not correct/ complete.
This question was beat to death several years ago on this BB.
Thu, Jul 21, 2022 7:11 PM
rax200
Hi All,
current price for 3b0889 and you require two and in Aussie you add 10% gst
 [attachment=68423]Screenshot_20220722-065136_Chrome.jpg[/attachment]
regards
Fri, Jul 22, 2022 6:54 AM
kracked1
Reply to rax200:
Hi All,
regards
Current Ziegler Mn price is $143.xx. I did find the gasket thread to reference the full list of gaskets needed.
Fri, Jul 22, 2022 6:23 PM
Thank you received: 289
Reply to kracked1:
My very first D4 revival project required new cork seals for the transmission cover. I about fell over when I saw what the invoice was just for the cork. I vowed to use something cheaper next time, such as rubber rope, which I was able to buy an entire 300' spool of it for way less money. Some say it was not right, but it works just as well if not better for less. JM
Fri, Jul 22, 2022 6:31 PM
Mike Meyer
Thank you received: 6
I bought a 3/8" thick sheet of rubberized cork knowing that I had a few tranny covers to work on, and cut replacement strips out of that.
Sat, Jul 23, 2022 12:38 AM
restore49
Reply to Mike Meyer:
Are these covers over 12" wide?
Sat, Jul 23, 2022 5:27 AM
Reply to restore49:
yes the main cover is. its about 4ft square. the inspection cover however is about ten inches square and uses a simple sheet gasket which is easy to make.
because the main cover gasket is moulded cork or felt hence the price. also rarer it is to replace the part the more expensive. rad caps for d46/7u are au$150.
when dad bought the one for ours i swear i heard mum yelling about the price and i live a few blocks away from them. yet common arts like the button type grease fittings are cheap at under 10 bucks each.
Sat, Jul 23, 2022 2:13 PM
