Cost of moving a D9
Cost of moving a D9
Showing 1 to 10 of 10 results
Kid at Heart
Send a private message to Kid at Heart
For those who have moved large, heavy equipment, any ideas of what it would cost to move a D9 about 250 miles within a single state? And would it be better to move it with or without the blade attatched? The blade is currently off as the tractor was traditionally used for pulling a pan.
Regards,
David
Thu, Aug 26, 2010 8:24 PM
7upuller
Send a pm to D4-e, he owns a low bed service. I would guess $1500-$2000 from my past dealings.-glen
Fri, Aug 27, 2010 12:10 PM
d4e
Send a private message to d4e
Reply to 7upuller:
David, Glen is in the price range. $ 1500.00 -$ 2000.00. There are a lot of variable
that determine the price. What model D9. How wide is the blade. What is
the height of the machine.You need to physically measure the height and
width so you dont get hit with extra costs do to the wrong dimensions.
happens to us all the time. Is there easy access for the lowbed at the pickup
drop location. As far as the blade, if the blade is under 12' wide most states
states dont require a pilot car unless you are on a two lane road or are in the
hills. Since the blade is off I would ship it with it off unless you need it on at
the drop in. You would have to way the cost of transporting it with the blade
on versus the cost and capabilites of installing it at the drop location. Didnt
mean to be such long winded just trying to help you avoid extra charges.
John
Fri, Aug 27, 2010 10:10 PM
d4e
Reply to d4e:
John
Hey Glen I moved a 651 out of Bakersfield yesterday. When we left 114 degrees.
Due to the height I had to go over Tehachapi back down 395.
Fri, Aug 27, 2010 10:20 PM
Mike Walsh
Reply to 7upuller:
I assume you are talking about a D9 18A. The issues you need to address are over height, overweight and overwidth for your state. Overheight is probably not an issue with an 18A.
Overweight is managed by the trailer. The more weight, the more trailer you need. This increases cost. I do not know your weight limits in MO. Here in CA a 5 axle lowbed can handle around an 87K payload (with permits) if the truck tractor is properly configured.
Overwidth is going to be a problem with the blade installed. You will need permits and probably a pilot car or two. If you move with the blade off, you have the added cost of moving the blade by itself. This may be cheaper if you can do it yourself.
Best advise is to talk to a local lowbed company and a local contractor about local rates, permits and pilot cars. The cheapest way to move anything is one way. If you are not in a hurry, you might look for someone willing to backhaul the 9 for you. It costs almost as much to road empty for 250 miles as it does loaded. Cut your haul in half. These days, lowbed companies here in CA are bidding jobs much cheaper just to keep the trucks on the road. If you find a lowbed company or contractor traveling to your area empty, they will probably give you a good price to move the 9, even if it means a slight detour to pick it up or drop it off. Hope this helps.
Fri, Aug 27, 2010 10:34 PM
cbd91974
Send a private message to cbd91974
Reply to Mike Walsh:
I sent you a P.M. about transport here in mo.
Sat, Aug 28, 2010 1:43 AM
Kid at Heart
Reply to cbd91974:
Thanks for the help guys. This would most likely be going to South-Eastern or South-Central Missouri. But I have to find out if the timber guy would let me access some of his property.
Regards,
David
Sat, Aug 28, 2010 7:20 AM
MichaelHoward
Send a private message to MichaelHoward
What do you think he would charge to move a D6 8U from Yuma AZ to frotwalton beach FL no blade a farm tractor ?[quote="Kid at Heart"]For those who have moved large, heavy equipment, any ideas of what it would cost to move a D9 about 250 miles within a single state? And would it be better to move it with or without the blade attatched? The blade is currently off as the tractor was traditionally used for pulling a pan.
Regards,
David[/quote]
1957 D6 9U Ford 3000 2002 HD with a 30 shot of NOS 1978 Ford Bronco 1969 lincoln 2 Door Coupe 460 500hp and a 1972 Ford F 100 that I cant find time to put back together.
Mon, Feb 21, 2011 9:44 AM
Walter
Send a private message to Walter
Regards,
David[/quote]
I would check with Jim Powers of Powers Hauling in St. Louis, MO. They haul heavy equiptment. I had a D4 picked up from their facility by a company called River Bend Hot Shots and they brought it to NC for $1150.00 approx. 1000 miles....of course mine was
a LOT smaller than what you've got!
Mon, Feb 21, 2011 10:08 AM
MichaelHoward
Reply to Walter:
Regards,
David[/quote]
Thanks do you have his phone #[quote="Walter"]I would check with Jim Powers of Powers Hauling in St. Louis, MO. They haul heavy equiptment. I had a D4 picked up from their facility by a company called River Bend Hot Shots and they brought it to NC for $1150.00 approx. 1000 miles....of course mine was
a LOT smaller than what you've got![/quote]
Tue, Feb 22, 2011 6:56 AM
CatKen
Send a private message to CatKen
Reply to MichaelHoward:
Call Crane Heavy Hall or something like that from Kansas City, Kansas. Not sure the correct name but they are the big dogs around there.
Wed, Feb 23, 2011 1:25 AM
| Kingaroy, Queensland
