Correct cable for a 127 unit
farmerfred
Send a private message to farmerfred
Went to Cat to get a roll of cable, only to find out they don't offer it any more.
Can someone tell me the correct cable to use in a 127 live unit on a D7E 47A?
Does anyone know a place to purchase cable or order it online that's not foreign
made junk? Thank you.
Wed, Feb 24, 2016 9:22 AM
Thank you received: 98
Hi, Farmerfred.
All Cat CCUs use 1/2" wire rope and I think it is supposed to be Lang's lay rope with a rope core.
I am open to correction on this.
Wed, Feb 24, 2016 10:42 AM
razz
Send a private message to razz
Hi, Farmerfred.
If you dont need it right now I can probably help you be back next week. Is Iit just for blade. I am clear lake.
Wed, Feb 24, 2016 11:31 AM
JoeG
Send a private message to JoeG
Reply to razz:
You need 1/2 diameter 6x9 right lang lay, IWRC (Independent wire rope core), Improved Plow Steel Type. You can get way with most 1/2 cable that is right lang lay and not rotation resistant. You can tell the two apart by the first number, the 6 is smaller than the 9, it will work for multi part reeving. If you get a rotation resistant cable, say a 19x7, it is not meant for multi part reeving (hence the resistance to rotation) and can open up when used in multi part application. Those numbers mean how many bundles of how many strands of wire form the cable. If you have a crane rental company in your area you can inquire about cable with them, they will likely have a good source. Or google.
Wed, Feb 24, 2016 5:09 PM
old-iron-habit
[quote="farmerfred"]Went to Cat to get a roll of cable, only to find out they don't offer it any more.
made junk? Thank you.[/quote]
Any construction rigging supply will be able to help you out. Olson Chain and Cable comes to mind in my area. A goggle should turn up a few suppliers.
Wed, Feb 24, 2016 11:00 PM
Thank you received: 39
Reply to old-iron-habit:
Most any good rigging supply house should have choice of foreign or domestic cable.
Wed, Feb 24, 2016 11:04 PM
