Reply to 3J1Bill:
The CAT 22 with bubbles in the radiator: Re torque the Cylinder head as these are thick gaskets and will compress. The CAT 22 with water in the oil: Drain the crankcase and suck out the oil in the front oil pan camber through the oil fill spot. I use a boat oil changing pump. Then fill rad. with water and see if water drips out the drain plug. This will save wasting new oil. Also the CAT 22 is not a pressurized cooling system and I have found stop leak products work best with pressurize systems. Both tractors: Take off the valve covers and check the freeze plug under the rocker arm. Hope this helps. Bill
I like the sodium Silicate method, or waterglas.
Granma used to keep eggs in it. A large crack sealed with this looks like glass is in the crack. Some of the coolant flowing through the crack gets converted into steam upon coming out of the block, leaving behind molecules of liquid glass in the crack. The heat inside that crack melts the liquid glass molecules, helping any subsequent molecules stick together and form a solid sheet of glass.
I have used it successfully for large cracks. I prefer to heat up the engine to boiling under load with a covered rad, as the evaporating water in the crack helps deposit this. Waterglas will stay solid and in place until heated to well above the temperature of deposit (boiling) in the #6 note below.
Here's the process:
1. Remove the anti-freeze
. Calculate the amount of sodium silicate you need based on the coolant capacity of the car. The cooling system of a modern car has 10 to 20 quart coolant capacity. The amount of sodium silicate you need is about 2.5% up to 5% of the total amount of coolant. For example if the coolant capacity is 20 quarts, you only need 1/2 quarts up to 1 quart of sodium silicate.
2. Empty (and save) the entire antifreeze/coolant liquid from the radiator/cooling system.
3. Disconnect the heater.
4. Fill up the radiator/cooling system up to about 90% with regular water.
5. Start the engine and let it warm up before the sodium silicate is added. Then remove the radiator cap and add the amount of liquid sodium silicate you have calculated. The engine continues to run until the leak is sealed.
6. Let the engine run an additional 1 to 4 hours. Then drive it at high speed for another 30 minutes.
7. Empty the water/sodium silicate solution from the entire cooling system and re-fill the cooling system with anti-freeze you removed in step 2.
8. After about 200 miles driving, replace the anti-freeze with new anti-freeze.
