Don't see those very often, or valves that have the holes or slot.
Hah! Now I know what the slots on the valve face are for!
I’m old enough to remember the cheapo suction cup tool that you spun with both palms.
Cats Forever
[quote="d2gary"]My neighbor knew what it was and got it at a garage sale
Wish I had it last month for my pony motor
Came with extra drive bits and works like it should
[/quote]
That is cool....I have one similar to that one, only mine has a suction cup on the end to hold the valve.
These Neway cutters are a bit expensive, but they work terrific on pony seats. You can put the seat right where you want it on the valve face and make it as wide or narrow as you please.![]()
Cats Forever
OCM, What cutter number/size did you use and was it possibly on a D4 pony? I'm still in the stone age!! :loco:
Jim,
I have two D6 2U size in process and also two D2/D4 Ponys that I'm working on. I bought the CU293 and CU645 Neway Cutters. I chose these because I had a smaller set with multiple heads for small engines and these expanded my range of valve sizes up quite a bit.
