Control Handle Grip rejuvenation or repair
BobD
Send a private message to BobD
Working on a Twenty that has control handle grips that are kinda pithy. What are some methods for rejuvenating the grips on these early gas tractors? If needed, what material would be used to create new ones?
Bob
Mon, Dec 4, 2006 8:32 AM
terrywelch_archive
Bob, they are hard enough you can either use GOOD body filler or epoxy for flexable bumper repair or something like Lord Fusior. The ones on the Twenty I am working on was in good shape exept that had some scratchs and have been painted over. I have repaired many a cracked steering wheel on wheeled tractors using the epoxy first to fill the major cracks and then a fine layer of body filler to give it the finsh coat before prime and painting.
Terry
No complaining on titles here.
Mon, Dec 4, 2006 8:45 AM
2HIGHTEN
Send a private message to 2HIGHTEN
Reply to terrywelch_archive:
Terry
The steering and clutch control handles are a common part to a lot of newer tractors and are avaible from cat. The old ones are very sharp on the tip of the metal in side of the composition handle and have caused nasty cuts in hands. Ron Meeder
Mon, Dec 4, 2006 8:51 AM
Steve A
BobD
These are available from Jim Zimmerman, I think I last paid $8 each
Mon, Dec 4, 2006 8:53 AM
