Concrete or no concrete
Showing 1 to 10 of 33 results
D4 Andy
Send a private message to D4 Andy
All,
I recently build a 40'x60'x16' pole building to house my toys. I have a D4 7U, D2 4U ,D2 5U, and a Cat 922B wheel loader. Along with other various tractors and toys ect... I have not poured concrete yet. I was planning on doing it in the spring. I am a bit torn as whether my Cat dozers will ruin my concrete. I was thinking of using old conveyor belting as a cushion under the tracks to keep the grousers from tearing it up.
Im sure some of you guys out there have concrete and some not. Was hoping to hear from both sides and suggetions from each to help me make up my mind.
Thanks in advance for any input anyone may have.
Andy
Central Pennsylvania
Wed, Jan 30, 2013 3:10 AM
chriscokid
We run ours on concrete and have had no problems but it is 8"-10" thick.
The conveyour belt would work just fine.
If you plan to use it just for storage i would save the money and do a gravel floor but if you plan to do any reapir work concrete is the way to go.
Wed, Jan 30, 2013 3:37 AM
Reply to chriscokid:
four pieces of heavy timber sheathing that each are the length of the track works well too to save the concrete.
if the machines are only driven in and out on a straight line others have embedded RR track even with the top surface of the concrete---if you have different gage widths that might be a problem
If you go with concrete add mesh or rebar--concrete always tends to crack either from loading or from shrinkage and the steel will keep the cracks tighter.
if gravel you will probably have to regrade where you made turns.
Wed, Jan 30, 2013 3:53 AM
Reply to dpendzic:
One I use quite a bit for storage has 1/3 finished off as a concrete floored, heat/air conditioned work shop.
The other 2/3 is unheated gravel fill to park tractors on.
Wed, Jan 30, 2013 4:45 AM
Inter674
Reply to dpendzic:
Steel?
I noticed the British Tank Museum at Bovington UK - also home for the Army's tank Regiment - uses steel sheets embedded into concrete flooring.
It was fun to see them drifting the combat tanks in and out of the shed area on a wet day.
Wed, Jan 30, 2013 4:46 AM
64farmboy
Reply to Inter674:
Steel?
When we poured the floor in my Buddie"s work shop for his construction business, we poured it 10 inches thick and put radiant floor heating in it. Makes a great floor to work on with a creeper, takes a while to warm up big iron (he has a D8, D6 and JD 550 for tracked machines. He lays down a couple of rough cut 2 X 12 oak planks to keep from digging up the floor surface. Machines need to be inside for a couple of days to warm up to room temp.
Regards Dennie
Wed, Jan 30, 2013 5:40 AM
Painter
Send a private message to Painter
Reply to 64farmboy:
Regards Dennie
Compacted screenings work better than gravel for me, easier to walk on
Hi, My name is Dennis, and I am a Rust-a-holic!
D4 7U17091 D6 8U10305 1926 Cat 30 1955 Ford T800, 74 Ford LT9000 1936 K Allis
Wed, Jan 30, 2013 7:18 AM
old-iron-habit
Reply to Painter:
Not sure where in PA you are at but if you go with concrete make sure you prep the soil underneath to insure you do not frost heave and crack. That's a lot of concrete money and you want it to last. A good bed of gravel or sand that will drain should do the trick. Adding reinforcing is cheap insurance when placing concrete.
Oh, by the way. Make sure it is thick enough to hold that D8 you will come across some day. You know, the one you do not know you just have to have yet. LOL
Wed, Jan 30, 2013 7:32 AM
blackkw
Send a private message to blackkw
Reply to Painter:
There is a dozer grade concrete, I think its rated at 10,000 lbs. test. You can run on it with most dozers and excavators with out tearing it up. This is what most equipment shops use
Wed, Jan 30, 2013 7:36 AM
Steve A
Reply to blackkw:
I vote with drujinin, have a small area for a work shop with concrete that you can heat, infloor is great if you leave it on, otherwise wood heat or overhead radiant tube heaters are instant on/off, Crushed conccrete, gravel or limestone is far cheaper for the rest of the cold storage area. 1 more thing, I used a product called cure seal on the concret, is is applied as soon as the mason is done, it slows the cure to make it stronger and seals the surfas so you can wipe up oil with ease and makes it easier to sweep.
Wed, Jan 30, 2013 8:01 AM
B4D2
Reply to Steve A:
When I built the CPHQ shop, I poured concrete over the entire surface. The main floor is "only" 6" thick with reinforcing mesh. Underneath is compacted sand fill that was allowed to settle over the winter with plenty of rain and snowmelt to allow proper settling. It was compacted again prior to the pour. My biggest machine is a 933. I use heavy rubber coated conveyor for a pad upon which to drive. I risked driving across an unprotected portion, figuring I was going to only drive straight. It didn't matter, there are little crush marks all the way where the grouser tips came to bear. Also of note, I built a small studio apartment inside. That area was also poured concrete, but only 4" thick with 4" of foam insulation underneath. It was poured 1 inch higher than the shop floor to prevent any snowmelt or water from getting under the walls. Again, wire mesh, but that is standard here. Also, I put a good layer of 6 mil plastic vapor barrier under all of the concrete. I would advise one major improvement that no one else has offered. Regardless of your approach to the shop, the edge of the slab is a critical point upon which you will bear a lot of the weight of the machine. When pouring the slab, embed some long j bolts or bent all-thread at the aprons so that you can then also embed or bolt a long heavy angle iron (galvanized for rust even) along the exposed edge of the slab. I used planks and 2x lumber to try and protect mine, one slip and you will crack off the edge. Experience.
Wed, Jan 30, 2013 9:10 AM
