Complicated dozer lift mechanisms
Showing 1 to 10 of 27 results
MikeA
Send a private message to MikeA
Hey folks,
It's been awhile since I posted here. Building a new house. It's done so I'd like to see if I can find an answer to a question I've been pondering for a long time.
Why in the world were so many older dozer blade lift mechanisms so complicated? Did someone have patent protection on a direct cylinder to blade connection like seen on most newer blades?
I've got RD4 with a Kay-Bruner blade with so many pins and bushings that are worn that it's hard to control. A little wear in each one makes for a lot of uncontrolled movement of the blade.
Just really curious.
Thanks, Mike
Mon, Jan 21, 2008 3:15 AM
Thank you received: 39
I've often wondered about that myself.....seems like they went to great extremes to build an odd ball contraption to do the job.
I guess most of it stems from the fact that these tractors were not originally designed or foreseen as dozers......plus the desire to be able to mount on both narrow and wide gage limited the options. None of them were close to getting it right until the hardnose hydraulic cylinder mounting systems came about.
Mon, Jan 21, 2008 3:30 AM
MikeA
And yet it's not like it wasn't done. I've got this beautiful blade mount on my little 1941 Cletrac HG that has a very direct linkage. I don't know if the mount is of a different age, and it certainly looks custom built for this tractor, but it's very simple and strong as well as made to reinforce the frame at the attachment points. They made them, like mine with a hydraulic tilt or like another one I've got, with hydraulic angle. I think they could even be combined to have both for sort of 6 way blade. (Maybe a project when I have more time than sense.) It would have been mighty heavy on the front of the tractor but still pretty cool.
Photo of the Anderson blade with tilt mechanism: [img]http://groups.msn.com/MikesRustyandShinyStuff/constsructionequipment.msnw?action=ShowPhoto&PhotoID=372[/img]
MikeA
Mon, Jan 21, 2008 4:38 AM
Reply to MikeA:
MikeA
Interesting, that's a nice HG. I have a couple of Cletracs, an AG and an AD. I started to fabricate a blade patterned after the Anderson set up but.....another project back burnered. Got any more pics of how that internal blade tilt mechanism works? Thanks
Mon, Jan 21, 2008 6:17 AM
carlsharp
Send a private message to carlsharp
Both based on the fact that hydraulics were very new at the time...
A) Since seal technology was in its infancy, maybe all the levers, pins and links isolated the rams from direct impact loads that could spike the pressures enough to blow out the piston or gland seals.
😎 Like anything new and unproven, hydraulics were regarded with some skepticism by consumers, and building a system that looked more mechanical was a selling point.
CS
Carl Sharp
Chino, CA
2xPV15; 22 2F; D4 5T
Various other oddball stuff
Vids: http://www.youtube.com/profile?user=carl4043
Mon, Jan 21, 2008 1:45 PM
C.L.Bos
Send a private message to C.L.Bos
Reply to carlsharp:
CS
Hydraulic pressures used in the early days were very low, therefore the cylinders used were quite large. Direct acting cylinders would have been very bulky hanging on the front. Mechanical leverage was used since the cylinder push was less than modern hydraulics, as well.
Check out the LaPlant Choate blades used on the Cat 60 and 30 models from the 20's and 30's. The cylinder used on the back of the blade attachment was quite large.
Chuck Bos
Mon, Jan 21, 2008 7:45 PM
gwhdiesel75
Reply to C.L.Bos:
Chuck Bos
Mike, that is a beautiful paint job on the Cletrac. I've wondered if it would not have been a lot more efficient to put the cylindar at the front of the tractor to pull more or less directly upward on the blade instead of at an angle to the blade. I'm obviously no engineer, but it would seem that it would take less energy to pull up instead of at an angle. I think some modern Cats do pretty much that now days. GWH
Mon, Jan 21, 2008 8:39 PM
MikeA
Reply to gwhdiesel75:
Thanks, gwh. That urethane does look like it's wet when new. I used ProLine paint which, here in San Diego, is what they use at the shipyards for tank lining and environments with high abrasive action on the paint. It's holding up as well as you could expect on a tractor that I actually use.
CLBos, I'm sure you're right about the angle of the cylinder, but it was probably done that way because less metal (money) was required to mount it close to the frame. As an aftermarket accessory on a farming tractor without the hard nose Old Magnet mentioned it was probably cheaper to do it that way. On most of the old blades I've seen, including the Kay Bruner on my RD4, the mechanical advantage was actually a DISadvantage, as in a little movement of the cylinder moved the blade a lot. And a little wear causes a lot of slop. The cylinders seemed to be large diameter in order to get a lot of force (probably with low hyd. pressure and the seal issues, per carlsharp). Also, on the Cletrac, the cylinders are small but more than powerful enough to lift the front of the tractor way up in the air. This also makes me suspicious that it was built after hyd. pressures went up. It won't lift the blade real high though because of that positioning... about 16-18" above the ground. Plenty high for what I do.
Old Magnet- I'll put some more photos on the website as soon as my satellite figures it wants to work: [img]http://groups.msn.com/MikesRustyandShinyStuff/shoebox.msnw[/img]
Look on page two of the "Pictures" under the album "Construction Equipment"
Thanks for all the input! Maybe when it's all put together we've found a reason for all the Rube Goldberg madness.
Mike
Tue, Jan 22, 2008 5:05 AM
MikeA
Reply to MikeA:
Mike
Crap, the link didn't show up for the photos. Maybe if you cut and paste this one:
MikeA
Tue, Jan 22, 2008 5:08 AM
Reply to MikeA:
MikeA
MikeA,
Lots of neat pictures there. Are you the owner, operator, maintainer of all that stuff😊 😊 My hats off to you if that's the case.
Tue, Jan 22, 2008 6:57 AM
MikeA
MikeA,
Old Magnet,
Yep, I'm the guy who owns it and gets to do all the upkeep and maintenance. Right now most of my time is spent keeping as much of it as possible running and generally kept from getting any worse than it already is. I try to restore something once and awhile, but much will have to wait until retirement (not all that far off!). House building slowed things down for a year or more and there's more on that to do before I can get serious on the old stuff again.
I put some more detailed photos of the Anderson blade on the website: http://groups.msn.com/MikesRustyandShinyStuff/shoebox.msnw
A few people have been interested in the Anderson blade before. It's a nice design.....simple and strong.....just how I like it. No relation to me though. Ha!
MikeA
Tue, Jan 22, 2008 12:06 PM
