Combustion chamber question..
Showing 1 to 10 of 35 results
crazyfazy_7
Send a private message to crazyfazy_7
Hello again...still workin' on that ol' Cat from previous posts and I have yet another question. Is there a special socket that fits the fuel fitting that screws into the combustion chamber to remove it on a 955C, motor #12A 781? It seems to have a knurled edge. I've tried different sockets with no luck. I have the tool (splined bolt) to remove the combustion chamber so I can install new washers and O rings, but I can't get the fitting that the fuel line screws onto out to remove the chamber. I'll learn the ins and outs of this ol' machine yet!😕
Thanks in advance for your response!
Greg.
Sat, Aug 16, 2008 9:29 AM
Have you tried a 6 point 1" socket? Torque to 100 foot pounds.
Sat, Aug 16, 2008 9:49 AM
crazyfazy_7
I haven't tried a six point socket. The fitting is round with small notches all the way around it. I've tried 12 point 15/16" sockets and they almost work, but just barely slip when torque is applied. I will try the 6 point, 1" tomorrow though, Thanks for your answer.
Greg.
Sat, Aug 16, 2008 10:09 AM
WraithGTO
Send a private message to WraithGTO
Reply to crazyfazy_7:
Greg.
Not sure but this is just a idea,could it be a Torx style head or similar
Sat, Aug 16, 2008 11:25 AM
crazyfazy_7
Reply to WraithGTO:
...not sure if they had torx when these ol' machines were made, but it's an idea. I'm also not sure if they have a torx socket that big. The biggest I've seen is E-20, but again it's worth a try! Thanks for your help!😊
Sat, Aug 16, 2008 4:16 PM
WraithGTO
No worries, Thought it may be a long shot
Sat, Aug 16, 2008 5:18 PM
SJ
Send a private message to SJ
Reply to WraithGTO:
I can,t remember for sure but it seems Cat had a special socket for it that was splined for it.Been too many years since I worked on one.
Sat, Aug 16, 2008 6:48 PM
Greg.
Just wondering if someone did a neat job on it with a cold chisel? Doesn't sound like it though. All of them I ever saw were a plain hex nut. This would likely be a D330, D330C or a 3304???
We are talking about the hold-down nut for the injector in the PC chamber, right? If CAT made it, they will sell a tool to remove it. Might not be as much trouble as making something.
Sat, Aug 16, 2008 7:09 PM
8C 361
Thank you received: 12
If you have the 1" holdown nut out, the fuel fitting as you are calling it comes straight out. It doesn't un-screw. It might be stuck in there, maybe if you try a little penetrating oil and wiggle it a bit it will come out.
Tom
Sat, Aug 16, 2008 7:56 PM
Thank you received: 52
Reply to 8C 361:
Tom
Tom has it right😊
No special tool required......same as D4-7U D-315.
They have been known to be a bit sticky but need to pull straight out.
Sat, Aug 16, 2008 10:10 PM
SJ
Tom has it right😊
I took it that he was talking about the nut that holds the body and nozzle down in. I have seen a few of them nuts with a serrated top on them and takes that special tool to remove them.Most the nuts has the hex on them for removal.If the nut is out sometimes the nozzle and body gets stuck in there so it takes a little moving them around to get it to break loose.Sometimes if you tap the side of the body lightly it will loosen them up as I,ve done it many times.I had a good supply of metal caps you used to screw on the bodies and the injector pumps when you took the lines off so dirt etc. wouldn,t get in them so I,d screw one on and tap on it too. New pumps usually had just a plastic cap on them from the factory.
Sat, Aug 16, 2008 10:58 PM
