Cold Engine Oil Change?
kittyman1
it's good an engine is warm for draining oil...for oil and filter change..service etc..
=.does anyone notice if cold changes are suffice?  esp if in no hurry? etc?
- like cracking the drainplug and see what drains first? antifreeze? water? other nastys? etc..?
Thu, May 23, 2024 2:01 PM
cheshire cat
Send a private message to cheshire cat
Good idea if you are bringing a non running engine back to life , otherwise I would run it to working temperature so it drains out faster and because some dirt sludge will be in suspension with the oil ..
Mon, May 27, 2024 12:15 AM
kittyman1
Reply to cheshire cat:
good point Cheshire, much faster draining with warm oil would help flush sludge and other undesirables from pan..
Tue, May 28, 2024 2:45 PM
| Kingaroy, Queensland
