Clutch plate tightness D2
rlitt
Send a private message to rlitt
OK, got the tractor apart the clutch plate out the disc replaced. Getting ready to reassemble. How tight should the disc be in between the two clutch plates? Should it be free or snug?
Wed, Sep 26, 2018 4:58 AM
jmvmopar
Looks released now, you need to install it to adjust it properly.
Wed, Sep 26, 2018 6:29 AM
I think it should be centered and then locked in. Or else run a string around it and tape on with some sort of flimsy tape so it diesnt slip off and run the ends up out the adjustment cover so you can lift the disk up into alignment with the flywheel gear as you pull the tractor back together.
Wed, Sep 26, 2018 7:18 AM
catsilver
Finish assembly, adjust it and lock it with the disc centred to slide the flywheel over it on refitting the engine.
Wed, Sep 26, 2018 3:15 PM
rlitt
Reply to catsilver:
OK, I figured it out. I was just overthinking it. Once the assembly goes back into the housing, the disk slips into the fly will. Thanks
Wed, Sep 26, 2018 10:08 PM
| Kingaroy, Queensland
