Clutch Lining rivets
Showing 1 to 10 of 15 results
farmallzach
Send a private message to farmallzach
I am looking for the rivets to reline my clutch for my 7T2044 Cat 12 Grader, I did get the linings from Caterpiller but I could not get the rivets, the part number is 7B5055 or does anyone have any Ideas on what to use. Thanks
Sun, Jan 29, 2012 3:05 AM
Mike Meyer
Thank you received: 6
I've recently bought rivets for my D2 steering clutch plates from Florin Tractor Parts, I'm often amazed at what they have in stock, contact Judy there, she is A1.
regards
Mike
Sun, Jan 29, 2012 3:33 AM
farmallzach
Reply to Mike Meyer:
regards
Mike
I have dealt with Florin Tractor before, just this week as a matter of fact, bought main bearings, rod bearings, and some seals for my pony motor, I deal with Dana, but they had no rivets, I was lucky to get the linings from Cat, but they were not very cheap either.
Sun, Jan 29, 2012 3:41 AM
Mike Meyer
Reply to farmallzach:
Better take the new plates to a Clutch and Brake Shop, if they don't have the correct rivets then I'm sure the glue they use nowadays on clutch and brake relines will get the job done, it's made rivets obsolete
regards
Mike
Sun, Jan 29, 2012 3:45 AM
Jimmy w
Send a private message to Jimmy w
regards
Mike
Mike Meyers, Our matey boy catman has cat spec rivets for linings and old ex army stock linings ex cat surplus. I have seen boxes full of rivets for linings on pallets and in 1 ton crete's, I know a load of um where heading down the scrap processing yard as scrap.
JW
Sun, Jan 29, 2012 4:26 AM
willwingo
Thank you received: 8
Reply to Jimmy w:
JW
http://www.mcmaster.com/#standard-rivets/=g09mtj
Sun, Jan 29, 2012 5:47 AM
Thank you received: 93
the 7B5055 rivet is listed as 3/16" dia. x 13/32" long and stated to be for "star set" not the usual "roll set"
Grab the scan below for future reference whilst it is up.
Hope this helps.
Sun, Jan 29, 2012 6:29 AM
Willie
Reply to edb:
Hope this helps.
When I got my 60 the estate had tons of early Cat stuff for bigger tractors and his sons let me take everything I wanted. I hauled home a Brake lining machine and bunch of boxes of rivits but they are Trojan brand and number dont look like any here the have 10-7,7-9,7-7 ect. and best I can measure your size is 7 T 7. does that sound right to anyone
Sun, Jan 29, 2012 7:39 AM
Reply to Willie:
This chart should help you figure it out...
First number is trade size diameter, second number is length.
http://www.hansonrivet.com/pdf2008/D4%20BRAKE%20&%20PIERCING%20RIVETS.pdf
Mon, Jan 30, 2012 12:54 AM
Willie
Thanks OM thats what I need and from what I get there is he needs a 7/7, does that sound correct to you ?
Mon, Jan 30, 2012 1:48 AM
Reply to Willie:
Not quite.....would need to be a 7 - 6.5 to match the 13/32" length. The 7 would be 1/32" to long.
Mon, Jan 30, 2012 2:08 AM
