clutch disk for 22 caterpillar
22Catter
Send a private message to 22Catter
What are specs for the lining thickness on a clutch disc for a Cat 22. Are there any suppliers for Cat22 clutch discs ? Any info is appreciated.
Wed, Feb 20, 2013 6:39 AM
There are spec's on the thickness still available.
If the splines are not all slopped out in the center hub you can call around to find a brake and clutch relining facaility.
Last year NW4EVR had a 22 clutch done at a place in Milwauke WI, this year they did my 10 clutch.There is a place in Indiana that does them too. Plus I found out that there is a place in Rockford, IL that does this work also.
The way to find a place is to go into the old auto parts store and ask them if they know who can reline it. Not a chain store but that old almost out of business place in town or Napa. I use both places for goofy parts chasing and the old place usually can find it.
Wed, Feb 20, 2013 6:16 PM
thomas84
Send a private message to thomas84
Reply to drujinin:
I used a place in Muskegon Michigan a few years ago, It came back looking new, they sandblasted and painted it along with riveting the new disc's on for I think $70. If I remember right the person NW4evr had re-line his used an adhesive intead of rivets? Is that what they used on yours Jeff?
Thu, Feb 21, 2013 12:48 AM
Reply to thomas84:
NW had them glue on his linings.
They would have glued mine but a miscommunication and I ended up with new lings riveted.
Thu, Feb 21, 2013 1:34 AM
22Catter
Reply to drujinin:
Thanks for the help it should get me back in the field soon.
Thu, Feb 21, 2013 11:26 PM
chriscokid
Reply to 22Catter:
I was able to order the material from Master Carr and did the relining myself.
http://www.mcmaster.com/#clutch-lining/=lkvefy
Fri, Feb 22, 2013 5:12 AM
