clutch assembly
clutch assembly
CatKen
Send a private message to CatKen
Would like to know the stack height of the clutch assembly? Would appreciate the info. Ours aren't the best and maybe better to get new ones. Tks Ken
Wed, Feb 23, 2011 6:13 AM
DDDfarmer
Send a private message to DDDfarmer
here is a link to a page that might help.http://www.tractorparts.com/spec_sheet.htm
Wed, Feb 23, 2011 6:45 AM
Thank you received: 62
Reply to DDDfarmer:
Would be helpful if we knew which tractor your working on.Cat never seemed to put that in there manuals,but do think I have seen a link to some one that has put the numbers together.I will say I have used 2 or 3 more plates than a new steering clutch would us when using used parts.Even though the manual says to us only one.Since they were the metallic ones they never gave any problem.So it depends how hard or how much you intend to use this tractor,and if you can find some extra used parts to bring the thickness up. Ray
Fri, Feb 25, 2011 12:28 AM
CatKen
Reply to Ray54:
Tks DDDfarmer. That info worked. This is a D6 converted to rubber tires. I believe this was converted at Ziegler's in Minnesota-Link Belt sprockets and chains in the drive housing. Have to call Ziegler back and see if they found any old drawing in some old files.
Fri, Feb 25, 2011 10:52 AM
