Clutch adjustment
Clutch adjustment
Zaddacksod
Send a private message to Zaddacksod
I have a D4 cat with a serial#7U40953 and Trans #5H607. Does anyone know how to adjust the flywheel clutch. this does not have the funnel. I believe it is a wet clutch.
Fri, Sep 11, 2015 1:25 AM
gemdozer
Thank you received: 25
For adjusting cluch you have to removed the cluch inspetion cover and loosed the 2 locknut 2 turns and tap plate slightly to be sure it is free on stud and rotate the flywell 180 degré and loosen the other locknut same manner ,turn the adjusting ring clockwise to tighten
Fri, Sep 11, 2015 2:51 AM
Zaddacksod
Reply to gemdozer:
would that be to nuts that are on the coupler if not where are they located
Fri, Sep 11, 2015 9:31 PM
Thank you received: 95
Reply to Zaddacksod:
Hi Z,
the scans below may help.
The lock nuts are on the rear face of the clutch pressure plate--for want of a better description. Be careful, do not over tighten them as the studs/nuts can strip easily--too loose and the clutch adjustment can slip.
Sat, Sep 12, 2015 6:04 AM
ShawnP
Send a private message to ShawnP
Reply to edb:
Hi Z,
When you try to turn the adjustment ring be sure to use a large enough tool such as a crowbar
Sat, Sep 12, 2015 9:24 AM
